Author Topic: Is there a quick way to tweak MAME INI files from MALA?  (Read 3693 times)
Kook
  • Last login:December 10, 2020, 02:36:25 pm
« on: December 02, 2006, 03:04:14 am »
Running MAME v0.110 here. In MALA, what I would like to do is hit a button that opens the INI file for the selected ROM (in Windows Notepad or whatever) and returns to MALA when I am done editing. In other words, I'm looking for a quicker way to tweak INI files. Is there a way to do this? I tried using the control panel viewer option (notepad.exe as the executable and %rom% on the command line) but it just makes MALA freeze.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
Re: Is there a quick way to tweak MAME INI files from MALA?
« Reply #1 on: December 02, 2006, 04:28:05 am »
Create a bat file and run notepad.exe with the command line dialog to open whatever file you want..
For example:
mame_ini.bat
Code: [Select]
@ECHO OFF
START C:\WINNT\NOTEPAD.EXE /w C:\emulators\MAME\mame_last\mame0110u2b_p3\mamep3.ini
EXIT
(replace the windows directory and mame ini location with the ones relevant to you)
Then go into the Mala options menu... then "Controller>Keyboard>External Applications" and set it as one of the apps, with a key to bring it up. (Remember to change the file type to "All Files" when browsing to be able to select it)
You're going to have to create a seperate bat file for every file you want to edit, and mala lets you choose 3 external apps, so I imagine that should suit you fine
« Last Edit: December 02, 2006, 04:32:24 am by OrganicJerk »
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #2 on: December 02, 2006, 05:41:42 am »
have you guys not had success using this feature?
See attached pic
Organic Jerk
    • OmeshPersaud.com
« Reply #3 on: December 02, 2006, 02:00:16 pm »
Personally that's what I do, but everyone has their reasons for things I guess...
I figure since you're taking out your keyboard for editing you might as well take out your mouse..
Kook
« Reply #4 on: December 04, 2006, 05:41:32 pm »
Sorry, I might not have been clear. It's not mame.ini I want to edit. I want to edit the ini file for the SELECTED GAME. For example, if I select Mortal Kombat II, I want to hit a button that opens mk2.ini in notepad. Get what I mean?
