Author Topic: Mala background image question  (Read 3855 times)
sealslayer
  • Last login:March 18, 2014, 04:41:30 pm
  • Why screw when you can bolt
« on: November 08, 2006, 04:34:33 pm »
I'm running mala 0.9.9 on my cab and have most of it set up but I'm struggling to get a background image to appear, does it have to be a certain size or file type?
I've read through mala's homepage and can't seem to find any info on it.
Cheers  :cheers:
  • Last login:December 16, 2025, 04:07:15 pm
Re: Mala background image question
« Reply #1 on: November 08, 2006, 04:47:10 pm »
Where is the image located? If I remember correctly, it has to be inside a folder you created with the same name
« Reply #2 on: November 08, 2006, 04:48:06 pm »
Look at how the default image is displayed. Use the same naming conventions as it did - in relation to the name of the background, folder name, etc.
Sorry I can't be more helpful - I'm nowhere near my setup. I just remember having the same issues.
sealslayer
« Reply #3 on: November 08, 2006, 05:20:20 pm »
Very strange it seems to work ok now :laugh2:
loadman
    • MaLa
« Reply #4 on: November 08, 2006, 05:40:30 pm »
Correct.
have a look at this tread. There are two ways you can operate with layout graphics
http://forum.arcadecontrols.com/index.php?topic=59675.0
