Author Topic: Help/Suggestions for setting up controls  (Read 1203 times)
twitami
  • Last login:December 22, 2016, 01:09:08 pm
« on: November 03, 2006, 02:21:51 am »
   I am building mutliple Control Panels for my cab, and have a question. I want to put an Exit, Pause, and Restart Game button on the cab seperate from the removable CPs. I am using a mini-Pac from Ultimarc in each CP -- I am too lazy to use one in the cab itself and wire up a connector of some kind, and I am not so good at electrical stuff :)
So anyway, how can I connect these three buttons seperatly from the mini-Pac? And I need to make sure they do the correct things.
Brian
  • Last login:November 09, 2025, 07:06:54 pm
Re: Help/Suggestions for setting up controls
« Reply #1 on: November 03, 2006, 05:37:13 am »
I would say to hack a keyboard... but you said you're not good at electrical stuff.  Buy another mini-pac??  Personally, I would wire a connector and only use one mini-pac in the cabinet, but to each his own!   :D
twitami
« Reply #2 on: November 03, 2006, 11:19:58 am »
I bought the mini-Pac with the pre-made wiring harness, so would I cut the wires before the harness, attach them to some sort of connector, then route them back out to the harness? If so, what is a good connector type to use?
Brian
« Reply #3 on: November 03, 2006, 01:22:23 pm »
people here seem to be fond of molex type connectors
severdhed
  • Last login:Today at 12:10:50 am
  • RIP Dinosaur Hippo
« Reply #4 on: November 03, 2006, 02:37:18 pm »
i hacked an old pc gamepad for my coinmechs, then used joy-to-key to make it work.  but that would require some minor soldering
