Author Topic: Can I use a megatouch monitor on a computer?  (Read 1198 times)
  • Last login:November 30, 2025, 12:59:41 am
« on: October 24, 2006, 08:47:34 am »
I lost an auction on a megatouch upright. I'm not sure if it's a bad thing or not. It has a 19" touchscreen in it and I was curious if anyone knew if I could use the existing monitor that was in it on a computer? My thinking was I could drop a computer right in the unit and connect the monitor to the computer and it would be a quick and dirty jukebox.
Ideally, I could open up a megatouch and it would have a VGA connection and a serial cable. All the megatouches I have run into thus far have run linux - but I wasn't sure what the connection to the computer was with these units.
Here are some pics:
« Last Edit: October 24, 2006, 08:49:24 am by leapinlew »
Ken Layton
  • Guru
  • Technician
Re: Can I use a megatouch monitor on a computer?
« Reply #1 on: October 24, 2006, 06:33:30 pm »
Depends on the version of Megatouch. Early ones used a CGA resolution monitor. All the later ones used a VGA resolution monitor.
The touchscreen glass was bonded to the face of the monitor and Merit used two touchscreen manufacturers: Microtouch (primary supplier and it's on 90% of the Megatouch screens) and ELO (secondary supplier on 10% of the machines out there). There is a touch screen controller with the glass too. You'd need to get drivers downloaded from the touchscreen maker.
