Author Topic: Trouble with my IPAC, little advice?  (Read 1659 times)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« on: October 21, 2006, 09:37:11 pm »
Well, I'd made sure that all my controls were wired up correctly, but 1sw7 and 1sw8 on the IPAC won't register a key press no matter what's connected. That I certainly blame on the hardware. Secondarily, I'm noticing that not all my key presses are being registered and sometimes they're delayed. This is pretty much in any game. I checked all the wiring and things are tight so... Computer runs sliky smooth, etc. I'm perplexed, anyone else been here? Thanks
GT
  • Last login:Today at 10:59:21 pm
Re: Trouble with my IPAC, little advice?
« Reply #1 on: October 22, 2006, 03:14:37 am »
I would figure in the year 2176 we wouldn't be using Ipacs.  ;D
Have you done any troubleshooting?
Such as - have you tried to run any cables specifically on a known good switch on a dedicated ground to sw7 and sw8 on the ipac?
Looking at your picture, your wiring looks nice and clean:
The grounds are soldered and the rest were quick connects? My previous issues that were similar to yours involved a faulty ground. It would sometimes register and any buttons after the ground in the daisy chain wouldn't work at all. Tracing the problem I was able to determine my ground didn't have a proper connect and the ipac was fine.
releasedtruth
  • Projected Nexus
« Reply #2 on: October 22, 2006, 12:21:02 pm »
Haha, you're right! I think in 2176 we use IPAC 5000s, but I didn't bring one back from the future sadly. That's a good point with the ground. I did the single wire for cleanness sake, but I never thought it would cause me problems. I'm gonna try that passmark program next. Andy at Ultimarc is seriously quick to respond, great service thus far. I'll update as I figure this out. Other than the overrunning targets and some delayed presses, things are good!
GT
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #3 on: October 22, 2006, 12:36:10 pm »
Correct me if I'm wrong but aren't sw7 and sw8 the inputs that aren't implemented in Mame by default? I know I had to set these up in (tab) settings?
Of coarse this doesn't account for your delayed button presses.
My old user name was marlborroman13, but I kicked the habit many years ago!
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #4 on: October 22, 2006, 07:55:41 pm »
I had ipac troubles.  It wouldn't shift.  And some button press issues.  Turned out I had a short.  I bent one of the quick connects installing the CP.  If I remember it was shorted to the common on another button or something, so it was basically registering a held down key all of the time.  It was on one of the higher numbered buttons on the 2up side, so it was little used and I didn't notice it.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: October 23, 2006, 06:21:21 am »
Yes those controls which are un-assigned to any keystroke in MAME (P2 buttons 5 upwards) are a constant source of confusion! I wish the MAME devs would assign them by default!
Andy
releasedtruth
  • Projected Nexus
« Reply #6 on: October 23, 2006, 10:56:34 am »
When it worked, I used 1SW7 as 'shift' and 2SW7 as shift-escape. It was real nice. Then I used  other buttons shifted as tab, ~, etc.  Dedicated shift buttons keep me out of trouble. Don't want to escape in the middle of a Streets of Rage battle. I'm going to figure this out with Andy's help, no doubt.
GT
