Author Topic: Control Panel Database: Post a picture of your Control Panel!  (Read 1018512 times)
0 Members and 11 Guests are viewing this topic.
dir
  • Last login:July 27, 2022, 09:46:46 pm
Re: Control Panel Database: Post a picture of your Control Panel!
« Reply #1000 on: May 04, 2019, 12:39:44 am »
Here's some pics.
« Last Edit: May 04, 2019, 12:45:17 am by dir »
dougdoberman
  • Last login:July 11, 2019, 11:32:28 pm
  • Woof!
« Reply #1001 on: May 28, 2019, 09:08:39 pm »
curate
[ noun kyoo r-it; verb kyoo-reyt, kyoo r-eyt ]
verb (used with object), cu·rat·ed, cu·rat·ing.
to pull together, sift through, and select for presentation, as music or website content:
Nah, he used it right.
If you can't be a good example at least try to be a horrible reminder.
Mr. Peabody
  • Last login:February 12, 2026, 12:32:17 am
« Reply #1002 on: May 29, 2019, 07:00:13 pm »
@dir: looks great. Cute overlay. The buttons around the spinner add slight congestion to the panel, and add no functionality.
curate
His use was a little off the connotation, that being care-taking, rather than assembling and culling. No one mentioned his great wiring job, though.
« Last Edit: May 29, 2019, 07:02:46 pm by Mr. Peabody »
Calvissuperman
  • Last login:November 19, 2019, 02:12:44 am
« Reply #1003 on: November 19, 2019, 02:13:02 am »
Found an image of the original control panel to Defender, and created my own art from the official art. It's a little busy, but I love it :P
DJO_Maverick
  • Last login:August 18, 2025, 05:32:31 pm
  • Chrono Crosser
« Reply #1004 on: April 10, 2020, 10:20:06 pm »
Just wrapped this one up for my first cab, the Chrono Crosser.  It's a pretty general jack-of-all trades design for 4 players that tries to not QUITE be a Frankenpanel.  I opted for auto-mappable Ultrastiks and a flight stick instead of a bespoke 4-way.  Main 20 buttons are RGB lit and auto-swap per-game using RGBCommander.
confusedtoomuch
  • Last login:October 24, 2021, 05:27:30 pm
« Reply #1005 on: May 26, 2020, 12:32:28 am »
That's killer!
danny_galaga
  • Last login:Yesterday at 08:34:19 am
    • dans cocktail lounge
« Reply #1006 on: May 27, 2020, 08:51:54 pm »
I'll add mine to the mix (",)
The controls are set in the tempered glass. To avoid too many holes in the glass, the joysticks (servostiks) are mounted on a base. Features touch controls for P1 P2 and coin buttons. Turns out its not a good idea having them between the buttons like I did as you can sometimes set one of them off while button mashing  :lol  I put them there because the CRT was affecting the touch controls sometimes due to the magnetic field. If I used an LCD (which I regret not doing) then they would have been up the side of the bezel, far far away from the buttons!  Talking of buttons, there is a minimum distance between holes in tempered glass. Mine ended up a bit bigger than needed which meant the already not ideal spacing was even further apart. If I had to do it again, I'd get them to use imperial sizing (was in millmetres) and that should get the switches just that much closer together.
http://forum.arcadecontrols.com/index.php/topic,144934.0.html
« Last Edit: May 27, 2020, 09:14:12 pm by danny_galaga »
  • Last login:Today at 06:46:54 am
« Reply #1007 on: May 27, 2020, 09:13:51 pm »
That is pretty snazzy. Did you drill the glass and then have it tempered?
danny_galaga
« Reply #1008 on: May 27, 2020, 09:17:04 pm »
Glass guys did that. CNC I think. Then tempered. There is a price per hole which meant the holes added up to costing more than the glass!
« Reply #1009 on: May 27, 2020, 09:27:40 pm »
I can imagine it wasn't cheap. It turned out nice.
I have drilled lots of holes in glass. It can be an adventure. Especially drilling aquariums. You only get one chance.
imacomputa
  • Last login:April 09, 2025, 05:15:06 pm
« Reply #1010 on: June 02, 2020, 03:29:36 am »
This is my first time posting anything on here.
I want to say, there are so many incredible CPs in this thread! Major inspiration going from page to page.
« Last Edit: June 02, 2020, 03:45:46 am by imacomputa »
RxBrad
  • Last login:May 31, 2023, 12:41:00 pm
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #1011 on: July 13, 2020, 03:46:48 pm »
You can download the GIMP image file for it here (warning: it's almost 200MB): https://www.dropbox.com/s/2gpfo1ivag3yxih/Arcade%20Control%20Panel.xcf?dl=0
JRobATL
  • Last login:September 27, 2022, 10:20:34 am
  • Completed - Tron Legacy
    • forum.arcadecontrols.com/index.php/topic,162637.0.html
« Reply #1012 on: July 17, 2020, 09:10:19 am »
This was my first build.  The buttons are all RGB-LED and are controlled by LEDBlinky to provide voice function and illumination for each game.
I also used the TR2N font and Word Art to create the custom button labels in maintaining the Tron Legacy theme of the cab.
The joysticks are Sanwa J-sticks with P1  being a servostik.  I love it's automated 4-way and 8-way adjustment. Thanks, Andy @ Ultimarc!
The mini-flight stick is from Groovy Game Gear and is wired in parallel to the P1 controls. (thanks, Scott!)
The spinner detaches and fits a 6" steering wheel (both purchased from Ultimarc) in case my friends feel like playing Pole Position, Outrun, Ivan Ironman, etc.
« Last Edit: July 17, 2020, 09:23:21 am by JRobATL »
mjwolfe
  • Last login:April 26, 2021, 02:36:56 am
« Reply #1013 on: August 22, 2020, 08:57:58 pm »
Here's my control panel before/after enabling the lighting:
I built the control panel as an inner sleeve that just slides into the top of the outer control box. Only needs two cables to attach to the cabinet. The control box and sleeve use a 5 degree slope for comfort. The controls are two ServoSticks, two ultimarc spinners and trackball and 18 Spectra Eclipse RGB LED buttons.
marcux
  • Last login:September 08, 2020, 12:45:17 am
« Reply #1014 on: September 07, 2020, 09:57:18 pm »
This is what I have done so far.. hand crafted myself, still sorta putting it together.. ;)
And my buttons
« Last Edit: September 07, 2020, 09:58:49 pm by marcux »
« Reply #1015 on: September 07, 2020, 10:37:13 pm »
I didn't know SpaceX made Christmas trees.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #1016 on: September 09, 2020, 05:58:35 pm »
JK! It's just my test rig
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
« Reply #1017 on: October 03, 2020, 03:57:04 am »
My Naomicab control panel  :)
« Last Edit: October 03, 2020, 04:08:34 am by SuperMagoAlex »
« Reply #1018 on: January 31, 2021, 05:06:47 pm »
bobbyb13
  • Last login:Today at 02:41:58 pm
« Reply #1019 on: January 31, 2021, 06:10:58 pm »
Love how clean this looks (both sides!)
How was setting up that ServoStik?
tbonge
  • Last login:March 04, 2021, 05:22:42 pm
« Reply #1020 on: March 01, 2021, 04:50:16 pm »
edekoning
Bambam1963
  • Last login:March 09, 2024, 11:46:07 pm
  • I love this stuff man!-
« Reply #1022 on: July 27, 2021, 03:29:56 pm »
And Spy Hunter and Tron for good measure - (That Moon Patrol is actually an 8-way stick, the game was all original outside, mame inside  ;D I built that for a friend though)
Love it.
I am an oldie, who used to troll here years ago.  Now I am back to tweak my machine and help a friend build his.
Bambam1963
« Reply #1023 on: July 27, 2021, 03:36:26 pm »
Here is my old girl.  The artwork was from an "Asteroids" cabinet, which was one of my favourite games of 1979.
« Last Edit: July 27, 2021, 03:39:11 pm by Bambam1963 »
Bambam1963
Bambam1963
« Reply #1025 on: July 27, 2021, 03:43:35 pm »
And my buttons
That is next level stuff.  Very cool.
Jakhman614
  • Last login:August 10, 2021, 08:54:18 am
« Reply #1026 on: August 09, 2021, 09:30:09 pm »
Hey guys I'm trying to upgrade to a 4 player control panel with a trackball.I currently have a 2 player. My question is the template I'm thinking of using the 3 and 4 player positions the joystick is cocked to the side so basically the up and down isn't directly in line with the screen as you will be standing at more of a slight angle in reference to the screen. How is that as far as playing is involved is it odd . When technically going right you would actually be moving the sick down and to the right in relation to the screen. Thanks. Alot off nice looking panels in here by the way.
  • Last login:Today at 07:04:36 pm
« Reply #1027 on: August 09, 2021, 10:17:06 pm »
The FAQ has some good info on this topic.
http://wiki.arcadecontrols.com/index.php/FAQ#Orientation
TL;DR version:  Green is good.  Red is bad.
Eksdad
  • Last login:March 06, 2022, 07:38:21 pm
« Reply #1028 on: February 06, 2022, 10:37:12 am »
Hello everyone,
I've have enjoyed this forum for years. I finally finished the cabinets I have been working on and wanted to share.
Thank you to the members that helped me straighten out the picture problem.
« Last Edit: February 18, 2022, 08:40:03 pm by Eksdad »
« Reply #1029 on: February 09, 2022, 10:07:06 am »
I don't know why the pics are stretched horizontally. It appears that you can download the pic and look at it as it should be.
AFAIK it's a combination of EXIF rotation and the images being over 1024 pixels wide.
Related thread with details and examples: http://forum.arcadecontrols.com/index.php/topic,163723.0.html
thomas_surles
« Reply #1030 on: February 09, 2022, 11:29:50 am »
I had to start screenshotting my photos before uploading here to lower the resolution. Otherwise it stretches them.
vyx313
  • Last login:February 14, 2023, 08:30:50 am
« Reply #1031 on: November 22, 2022, 08:04:37 pm »
@imacomputa, do you by chance have dimensions/a template for the control panel build? I've been browsing for quite a while and this looks like it will fit my need great. I've been trying to do some mock-ups but figuring out final dimensions is kind of a mystery at the moment.
Hydrolisk1792
  • Last login:September 11, 2023, 08:02:38 pm
  • Custom Cabinets and Games FTW!
« Reply #1032 on: November 23, 2022, 11:26:02 am »
what's with all the dust washers showing?
ahh, the age old debate. I prefer mine "under", but can see the argument to have them "over".
My Omega Race multiwilliams panel was under with Wicos, but I had to put them on top for Ultimarc Mag Stiks as they cannot be removed from the shafts. :(
I've always put them on the top, Looks cleaner, but scuffs up the panel after a lot of play...
Hardware Guy: It is a software problem!
Software Guy: It is a hardware problem!
Me: Hold My Beer!
Tommy714
  • Last login:November 02, 2024, 06:34:59 pm
« Reply #1033 on: January 17, 2023, 11:13:46 am »
I know, your gonna say "what's the purpose of 2 spinners, they are both for the X Axis?".  One is set up for the Y axis, and can be used as a second steering wheel in games like Iron Man Off Road or Demolition Derby.
The surface is Formica Laminate  on 5/8" particle board.  This is perfect for the 11/16" Chrome T-moulding.
Firebat138
  • Last login:January 29, 2026, 02:52:57 pm
  • Head Brewer and Arcade Enthusiast
« Reply #1034 on: January 17, 2023, 12:38:48 pm »
Looks great!!!!  Welcome to the "hobby" lol    its addicting
Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0
Click below to see my PinCab - PinWARS
http://forum.arcadecontrols.com/index.php/topic,164660.0.html
Pittyh
  • Last login:November 28, 2023, 06:38:33 am
« Reply #1035 on: October 27, 2023, 09:15:44 am »
Hi guys, first post.
Inspired by Daniel Spies' awesome cabinets.
Firebat138
« Reply #1036 on: January 31, 2024, 01:00:55 pm »
Love it, I am about to move to a new home and need to get back in to the hobby  So many new games out now
HitmanHart
  • Last login:May 10, 2025, 04:15:57 pm
  • You can do this!
« Reply #1037 on: February 25, 2024, 04:00:27 pm »
This is my first arcade machine build ever.  I thought about it for a while, then planned it, then decided to buy some components, and finally put it together in Nov/Dec of '23 and Jan '24.  I went for a full 4-player setup with 8 buttons at each, then added spinner, trackball, and flight stick as my budget allowed.  Overkill, I know, but it allows flexibility for customization and it turned out as perfect as I had seen it in my head when I was planning it.
There's a lot going on here, I know.  It's actually less crowded than it looks and super comfortable to use.  I'm planning a small add-on removable panel with the GRS analog flight yoke and will be adding Sinden light guns when they arrive (already ordered the light guns).
The picture of the full cabinet was slightly earlier in the process.  Since that pic was taken, I replaced the keyboard with a few custom buttons (using a keyboard encoder board), added the spinner, trackball (which doubles as a mouse in the main OS), and flight stick, but the control panel pic is where it's at today.
I've had a ton of fun building it and did it all with hand tools (no real workshop) and patience.  I've already had a couple of requests from friends to help them build their own like it - which I see as the highest compliment they could give me about it.
I want to thank everyone in this forum. You didn't know it, but all the pics and advice placed here helped me understand the nuances of a project like this and helped it be a success for me. It's much appreciated.
(update:  I added a third picture showing the GRS Flight Yoke and the Sinden light guns I installed...they all work amazingly well and the GRS Yoke has a mount you can buy with quick-release that works incredibly well.  100% worth the cost.)
« Last Edit: June 22, 2024, 10:49:40 pm by HitmanHart »
CKebz
  • Last login:December 26, 2025, 02:09:11 am
« Reply #1038 on: March 23, 2025, 09:34:50 pm »
This is all pre-build stuff, (TankStick Max/DTAP podium) except for the "stow-away" Star Wars flight yoke, and auto-calibrating 720 joystick. I also mounted the TV on a rotating swivel so portrait games like Punch-Out would look better.
Jeff
  • Last login:May 10, 2025, 01:18:50 pm
« Reply #1039 on: April 13, 2025, 09:26:46 pm »
My Gauntlet replica control panel. (I went with buttons for coins on the front instead of double coin doors--expensive).
« Last Edit: April 13, 2025, 09:29:02 pm by Jeff »
