Author Topic: Neo Geo MV-1F controller ports  (Read 1462 times)
  • Last login:February 28, 2026, 04:55:22 pm
« on: September 15, 2006, 05:48:00 am »
Anybody know where I can get connecters that will fit the controller ports on this motherboard?
They're the two black connectors above and to the right of the jamma connector.
http://www.hardmvs.com/html/MV-1F.htm
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: Neo Geo MV-1F controller ports
« Reply #1 on: September 15, 2006, 12:03:52 pm »
The ports fit AES (Neo-Geo home system) joysticks/controllers. These things are pretty hard to find (and somewhat expensive) these days.
OTOH,Neo-Geo controllers are all just straight circuits for each button.  You can build your own using these pinouts:
http://www.gamesx.com/controldata/neocont.htm
It uses a standard DB-15 plug, but diferent pinouts than a PCs gameport.
I never really understood why the arcade PCBs had these ports though, since the arcade cabinet's control panels are wired to the JAMMA-like edge connector. Maybe for testing PCBs?
J.Max
  • Last login:July 29, 2010, 10:46:27 pm
« Reply #2 on: September 16, 2006, 12:21:57 am »
I believe it's because they were going to add different types of controllers at one point for different types of games...but they never did it, except for Irritating Maze, which ended up using a totally different set up anyway.
