Author Topic: DOS MAME .61 won't allow 1 key to have 2 functions?  (Read 1677 times)
spystyle
« on: September 08, 2006, 10:32:13 pm »
Hello from Maine,
I got a beaten, converted, and gutted Gauntlet that I am bringing back to life with MAME!
Hooray!
I wired up the keywiz today and there were not enough inputs to have all the keys (35 out of 32) So, like the CP sticker shows, I intended to use "player's 2nd button" as "player's start" (lowering the count by 4 buttons now it's 31 of 32 inputs)
So "P1 button 2" is ALT, I tried to configure MAME to use ALT as "P1 button 2" and as "1 player start" - it allowed me to input that but it won't work. Apparently MAME won't allow 1 key to have 2 functions... Is there anyway I can get around that?
This is the very last obsticle I need to ovcercome before the Gauntlet is revived.
Thank you,
Craig
Thenasty
  • Trade Count: (+17)
  • Last login:May 28, 2026, 02:40:58 pm
Re: DOS MAME .61 won't allow 1 key to have 2 functions?
« Reply #1 on: September 08, 2006, 10:43:48 pm »
I remember before that you can do it but I don't know in this newer versions of MAME. Anyway, how about doing it the  HARDWARE level ? Just connect p1start and p1button2 as (ALT) so two buttons is ONE.
*edit*
Myabe this is not what you wanted....I may have interpreted it wrongly.
Maybe you ned to hook up in P1Button2  as  "ALT" and P1start(1). I don'tnow if Keywiz will have problem shorting those (ALT,1) two inputs.
« Last Edit: September 08, 2006, 10:47:35 pm by Thenasty »
Free VGA Breakout Cable
spystyle
« Reply #2 on: September 08, 2006, 10:46:55 pm »
I tried it on MAME32 .36 and it too won't allow ALT to be both
What a drag!
I can't do what you are suggesting because there is no 1,2,3,4 on my KeyWiz. I programmed it and I didn't have enough inputs (out of 32 available) for that so I assumed I could use 1 key for 2 functions in MAME.
Egads! Help!
Thenasty
« Reply #3 on: September 08, 2006, 10:50:46 pm »
you mean it does register in TAB but when you use it it won't work ?
Thenasty
« Reply #4 on: September 08, 2006, 10:55:14 pm »
I just tried it with 105 and it works....YOu have to do it in the INPUT THIS GAME MENU not the GENERAL.
spystyle
« Reply #5 on: September 09, 2006, 12:39:31 am »
Thanks for the replies "The Nasty"
I was able to get it to work in .61
It was a strange problem that was only in the Gauntlet ROM and no other game. I fixed it by putting "ALT 1" instead of just "ALT" - now it accepts just ALT and works fine, it just didn't like it when I put ALT only.
I also tried it with "ALT LCTRL" and it worked fine using just ALT as well.
Funky huh? It's only the Gauntlet ROM, I tried another game and that allows 1 button to have 2 functions just fine.
So, problem solved :)
Tomorrow my Gauntlet will be restored! (and better than before as it will now play 900 games and not require quarters)
Cheers,
Craig
