Author Topic: Interface Strobe Light with PC.. any thoughts??  (Read 2129 times)
JK99
  • Last login:December 04, 2003, 08:12:37 pm
« on: March 17, 2003, 07:51:26 pm »
Hey guys.
I recently built a strobe light from one of those electronic store kits to use with the video/mp3 jukebox side of my cabinet.
I'm wondering if anyone has any thoughts on how I could interface it with a PC and custom write software to control when the strobe is turned on and off.
The jukebox software I use is written in VB.
I was thinking more along the lines of making something that will 'flick' on the power to the strobe when there is a trigger received from the PC. Say via the COM port.
Any help, suggestions, thoughts.. would be very much appreciated.
Cheers guys.
JK
BobA
  • What Me Worry?
Re:Interface Strobe Light with PC.. any thoughts??
« Reply #1 on: March 17, 2003, 08:07:48 pm »
The serial port takes a bit of electronics to decode an output bit stream.  On the other hand the parallel port needs a minimal amount of hardware to interface to.  Here is a link to info on interfacing to the parallel port.  There are many other links re parallel port interfacing if you use a search engine.
http://www.doc.ic.ac.uk/~ih/doc/par/
BobA
JK99
« Reply #2 on: March 17, 2003, 08:33:01 pm »
Thanks mate
Nice info on the website
In particular this link
http://www.xs4all.nl/~sebdehne/pp_powerSwitch/switch.html
Would do exactly what I need.
I'd be wanting to control the on/off process using VB. Does anyone have methods of controlling the above device using VB?
Cheers
JK
« Reply #3 on: March 18, 2003, 03:49:16 pm »
I'm working on something.... be patient  :D
JK99
« Reply #4 on: March 18, 2003, 06:16:19 pm »
Sweet. I'd be interested to see what ya come up with.
I bought all the bits and have built what I think will work. Yet to test. Still have the 240V side of things to do from the relay, that shouldn't be too hard, assuming I dont fry ---my bottom---.
I also managed to get the necessary stuff to intergrate it with the video jukebox so if all goes well people will be strobing to the doof doof.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #5 on: March 19, 2003, 12:05:21 am »
If you could figure out a way, via serial or parallel, to control an output (it will involve special wiring and coding), then use a relay or triac circuit to control the light (you will need to use the +5V (or +3.3V) output of the computer, to drive something that can switch higher voltage (probably 120V or more), which powers the strobe.
