Author Topic: Mala video Question  (Read 7760 times)
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
Mala video Question
« on: July 11, 2006, 08:04:41 am »
I hate asking questions when i know the answer is out there but I have used search.
Okay so I just discovered emumovies.com and Ive been starting to build a collection of vids but when I use the previews in Mala the FE freezes and i need to right click with the mouse to get it to move again. Is there some setting that I'm over looking that neeeds to be checked off to that i can scroll through the games again or does Mala not handle video well?
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
Re: Mala video Question
« Reply #1 on: July 11, 2006, 09:49:21 am »
Blinky, do you have the proper video codec installed?  For the Mame vids, I think you need the xvid codec, but I'm not certain.  Hope this at least puts you on the right path.   :cheers:
BlinKY1337
« Reply #2 on: July 11, 2006, 12:48:00 pm »
Yes I have all the updated codecs and the video plays after a short delay but then mala refuses to scroll through games or change emulator until I right click on the mouse.
loadman
    • MaLa
« Reply #3 on: July 11, 2006, 05:46:18 pm »
Hi,
MaLa handles video well if you have the latest codec installed. I have the emumovies.com collection and it works very well with the latest xvid codec (as Ninten-doh says) found here
I assume the 'short delay' is due to your PC speed?
The mouse clicking thing is not right.
Can you e-mail me your mame.ini file?
[EDIT] sorry i meant mala.ini file       :banghead: [end of edit]
« Last Edit: July 11, 2006, 09:22:01 pm by loadman »
loadman
    • MaLa
« Reply #4 on: July 12, 2006, 01:30:41 am »
Thanks I got that
I had no problems but I have questions for you?
* Are you using the latest xvid Codec?
* Are you using MaLa 1.0  RC7  ?
* No path to the folder your videos was set in mala.ini you sent me?? Why? Video won't display in a layout without it being set. See pic 'mala75'
* What layout are you using?
* What Spec is your PC  (Processor speed and memory)
Suggestions regardless:
set you mame launch window state to hidden in options/mame/optional
enable display delay with only test selected as an exception in options/gui/options   (see pic 'mala76')
BlinKY1337
« Reply #5 on: July 12, 2006, 10:43:21 am »
answer to questions
-yes
-yes
-I dont have the mame videos yet i was using snes previews
-One i made myself (will be relasing publicly soon)
-2.8 intel 512 ram should be sufficient i think
When I get home from work I will try the changes you suggested, and my mame vids should be fininshed downloading, thanks for all your help
BlinKY1337
« Reply #6 on: July 13, 2006, 01:21:46 am »
Well it works just fine now i remade my layouts using the new layout creator and that seemed to be the problem must of messed somthing up the first time although i dont know how. Thanks everyone who took time to help out :)
Q*bert
  • Last login:January 21, 2023, 10:11:53 am
« Reply #7 on: July 18, 2006, 09:30:22 pm »
I have the same problems as Blinky did - using videos makes MaLa stop responing to keypresses.  The video displays correctly, but all I can do is use the right mouse button to call up the options menu.
I have downloded the suggested codec and made the option selections outlined above, but the changes make no difference.
I also tried designing a new layout as did Blinky, but still no change.
Has anyone else seen this?
Ninten-doh
« Reply #8 on: July 19, 2006, 08:44:44 am »
This happened to me randomly one time as well.  Worked fine before and after that one incident.  Strange thing that happens to me is when Mala first loads up, the first video clip does not appear.  Only after I move up or down the list do the videos start appearing.
BlinKY1337
« Reply #9 on: July 19, 2006, 05:48:30 pm »
Good to know I wasnt the only person to experiance problems with one of the easiest front ends to set up.
loadman
    • MaLa
« Reply #10 on: July 19, 2006, 08:02:45 pm »
That happens consistantly to me, not that I'm worried about it right now  ;)
