Author Topic: Display Woes  (Read 1317 times)
lloydcom
Display Woes
« on: June 27, 2006, 07:35:32 am »
Hello,
I'm bulding my cabinet that houses a X-arcade unit, but I have a width factor of the cabinet of 30 inches.  Now the surround will take in some of that space, but I'm still looking at a hole with a 15" VGA monitor.
My problems with this cabinet build have been endless with weight issues (creaking floors, plaster cracking below etc) so a nice big tv is out of the question.
I asked about mirror displays, but that is just so lame to implement in this situation.  So I'm looking at TFTs.
Now Scan (Uk) is ofering a nice LG TFT 19" for under
MYX
    • MYX Digital Blog
Re: Display Woes
« Reply #1 on: June 27, 2006, 07:48:35 am »
It is not the ideal situation, but it will still display just fine. I have been learning to set up my cab system oon my office system. My office is a flat pannel.
If it is the only way you can make it happen right now, then do it. Better to be playing than wondering what it would be like to play.  :D
M    Y    X
Forces21
  • Last login:March 02, 2011, 05:05:48 am
Re: Display Woes
« Reply #2 on: June 27, 2006, 08:03:41 am »
I've used Aria numerous times before and their service is very good and most products are at a very good price.
Here's a link to a low cost 19"
http://www.aria.co.uk/ProductInfoComm.asp?ID=17020
As for the use on an arcade, I use one at home & obviously on a laptop I carry around and I've been experimenting with MAME's scanline features, you can get some intersting effects using this (not quite the same as using a std res arcade monitor) but this does slow down the emulation but on some games looks more "Authentic".  Also If you purchase a vesa mount you "should" be able to turn the monitor on it's side to play vertical games vertically, just depends on how you want to mount the screen. Also the monitor mentioned above also has a DVI input so you have the best of everything :)
Hope all pans out well
Regards
Forces21
Havok
  • Trade Count: (+17)
Re: Display Woes
« Reply #3 on: June 27, 2006, 08:41:13 am »
My cab uses a LCD monitor with digital input, and looks great! You can even enable scan lines and such in Mame if you really want a "close" approximate to old CRT displays, but I was never a purist for display.
It also gives you the option for higher resolution games that arcade monitors just can't handle, and you've love having the ability to use small text - something an arcade monitor just can't do well...
lloydcom
Re: Display Woes
« Reply #4 on: June 27, 2006, 10:27:47 am »
Thank you very much for the quick replies.
The responses have made me take the plunge and that Aria 19" looks very nice with a 12ms rating and DVI inputs makes it all real easy.
Thanks again for all your help.
