Author Topic: Slik-Stik spinner tops  (Read 2469 times)
specfire
  • Last login:April 23, 2016, 10:39:09 pm
  • Shhh...
« on: April 25, 2006, 03:07:50 pm »
I am going to buy RandyT's spinner but that top has got to go.  I would buy from Oscar if I could but, as is obvious, he is closed.
Can anyone tell me if Slik-Stik's polished silver spinner tops are in fact stainless steel?  I know the coloured tops are anodized aluminum.
If they are steel, I am wondering if the extra weight of the steel vs the aluminum top would make direction changes more difficult than would be the case with an aluminum top.
Thanks, spec
Read to your kids, you'll all be better for it.
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
Re: Slik-Stik spinner tops
« Reply #1 on: April 25, 2006, 04:00:21 pm »
I originally bought the standard silver top, played around with it and exchanged it for a black standard only because black was better suited for my panel.  I wasn't observant enough to notice if the silver was steel or aluminum,(I want to say it was steel)  Regardless, I noticed 0 difference in weight or directional changes between the two.  Hope that helps.
whammoed
  • Last login:February 27, 2026, 04:03:09 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: April 25, 2006, 07:21:03 pm »
I have one, its aluminum.
specfire
  • Shhh...
« Reply #3 on: April 25, 2006, 08:08:51 pm »
Thanks for the info.
