February 16, 2026, 07:18:12 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Monitor/Video Forum
Wells K4500
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Wells K4500 (Read 4260 times)
20eyes
Trade Count:
+1
Full Member
Offline
Last login:July 01, 2009, 05:41:10 pm
I want to build my own arcade controls!
Wells K4500
on:
April 03, 2006, 06:40:27 pm »
So I finally did the cap kit on my wells k4500 in my galaxian machine and now it doesnt work. I cvan hear the monitor "running" but I dont get a picture.. I'm fairly certain I reconnected everything. I may end up pulling the boards off the monitor again and double checking. But I have no idea where to start looking for the problem.
Logged
grantspain
I personally prefer "bog trotter"
Trade Count:
+1
Full Member
Offline
Last login:August 16, 2025, 04:42:10 am
Re: Wells K4500
Reply #1 on:
April 03, 2006, 06:47:29 pm »
sometimes when you change the caps your picture will go dark,first turn up your screen volts on the lopti to see if you have any sort of picture(also look for an orange glow from the tube neck)
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #2 on:
April 03, 2006, 06:52:26 pm »
no glow from the neck
"lopti"?
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #3 on:
April 03, 2006, 06:58:23 pm »
loads of stuff,fuse,h.o.t,caps,lopti,dry joint,broken track-what was your original fault?
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #4 on:
April 03, 2006, 06:59:39 pm »
Screen was blurry and dim, but it did work.
Fuse is ok.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #5 on:
April 03, 2006, 07:05:48 pm »
blurry and dim denotes a lopti fault,but as your fault has changed you should retrace your steps-look for bad/broken tracks,check your values and polarity of your caps also all your plug/connections-in the end its gonna be something that you have done during the recapping process,oh and double check your neck card and pins
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #6 on:
April 03, 2006, 07:08:06 pm »
I'm not familair with the term "lopti"
I was thinking it was somthig I did, but the problem is WHAT lol.
I'll retrace my steps and see what I can come up with.
What should I check for on the neck card?
Logged
SirPeale
Green Mountain Man
Global Moderator
Trade Count:
+23
Full Member
Offline
Last login:August 04, 2023, 09:51:57 am
Arcade Repair in New England
Re: Wells K4500
Reply #7 on:
April 03, 2006, 07:11:02 pm »
Darn weirdos and their 'lopti'.
He means flyback.
Logged
Need a monitor "cap kit"? Click Here!
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #8 on:
April 03, 2006, 07:19:54 pm »
o.k then flyback transformer,we're not wierd YOU ARE.
,ON THE NECK CARD check for bent pins(tube itself) and broken track-do you get any noise from the chassis like a ticking or a buzz
Last Edit: April 03, 2006, 07:23:26 pm by grantspain
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #9 on:
April 03, 2006, 07:25:33 pm »
i hear buzzing.
the pins are slightly bent on the neck.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #10 on:
April 04, 2006, 05:56:00 am »
i reckon you have a bad piece of track on one the caps you changed,your gonna have to get a meter out and check continuity on all areas you worked on,have you turned up your screen volts pot on the FLYBACK yet,when i was talking about pins i mean't the pins on the tube itself.Line Output Transformer=lopti or loptx
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #11 on:
April 04, 2006, 03:45:25 pm »
I turned the black level pot all the way the other way and now I get a pink screen with vertical lines that keep flashing back and forth.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #12 on:
April 04, 2006, 04:34:16 pm »
well your monitor works,its just a problem with signal or adjustments,you need to check your contrast controls as well as the screen volts,and check your signal cable is good/plugged in correctly
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #13 on:
April 04, 2006, 06:06:52 pm »
Finally got it working. I tweaked the black level some more and i now have a picture but I can't seem to get the vertical hold set now.... More tweaking another day i guess. Thanks for all your help. I have alot more confidence in myself now.
Logged
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #14 on:
April 09, 2006, 03:58:06 pm »
I still cant get the vertical hold to stay. I can get it to stay for a few min then it starts to roll again.
I tried spray cleaner on the pot but that didn't help. Any ideas?
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #15 on:
April 09, 2006, 05:39:33 pm »
check your caps values are correct,if it locked before you capped it then its likely to be something you did
Logged
cw
Trade Count:
+7
Full Member
Offline
Last login:May 03, 2025, 09:26:58 pm
Game over man game over
Re: Wells K4500
Reply #16 on:
April 09, 2006, 07:28:52 pm »
sync
Logged
My collection
http://ggdb.com/Collectors/ViewMember.aspx?mid=298
20eyes
Trade Count:
+1
Full Member
Offline
Re: Wells K4500
Reply #17 on:
April 10, 2006, 10:06:03 am »
Quote from: cw on April 09, 2006, 07:28:52 pm
sync
I just checked my randy fromm book and you are exactly correct. Thanks!
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
Wells K4500
