Author Topic: What to seal CP/Cab with  (Read 1366 times)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« on: February 20, 2003, 06:53:20 pm »
What works well to seal your control panel/cab?  IE mainly to protect from water/moisture.. as well as create a good surface for painting..  there were tons of different kinds down at home depot..
also i have access to an air compressor with a spray paint attachment.... would like to utilize it if possible :)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:What to seal CP/Cab with
« Reply #1 on: February 20, 2003, 07:39:11 pm »
I used sanding sealer - about 3 coats because it's pretty thin.  And sand lightly between coats to smooth it down a bit.  Seals the grain perfectly.  I used a brush, though you may be able to use the spray gun.  Brush worked fine for me.
eightbit
  • My cab is never done...
« Reply #2 on: February 21, 2003, 08:39:55 am »
I used a roller on mine to get a slight texture. Use a spray gun if you want that polished glossy smooth car paint job look.
If your not experienced with the gun don't use it. You'll be a lot happier with a roller and you'll be done a lot sooner.
