Author Topic: Best drill bit to install 1/4" Spinner shaft  (Read 1891 times)
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« on: March 07, 2006, 12:51:11 pm »
Hey Gang,
Did a search and found a range.  What is the ideal bit to use to install a spinner with a quarter inch shaft.
Kevin
mark shaker
  • Last login:March 04, 2022, 09:27:06 pm
  • Oh Crikey!
    • Mark's Basement Arcade
Re: Best drill bit to install 1/4" Spinner shaft
« Reply #1 on: March 07, 2006, 08:53:23 pm »
3/8" ... 1/2" ... It doesn't really matter, as long as the the shaft does not rub the CP ans the knob covers the hole.
   - M
Necro
  • Last login:November 29, 2022, 08:22:22 pm
  • Building a 'Classic' MAME Cab
« Reply #2 on: March 07, 2006, 09:47:13 pm »
Depends on the spinner.
For instance, the Oscar spinners (at least the vortex) requires a larger hole then other spinners because of the small clip on it.
What kind are you talking about?
juggle50
« Reply #3 on: March 08, 2006, 01:44:58 am »
One with a 1/4" shaft.  I guess I'd like the hole to be as small as possible with out touching the spinner shaft.  I'm just not sure what the next size up from th 1/4" bit is.
quarterback
« Reply #4 on: March 08, 2006, 01:47:43 am »
5/16ths would probably work.  But, in the end, the hole and shaft are going to be under the top of the spinner, so it probably won't show anyway.
-- Chad Tower
juggle50
« Reply #5 on: March 08, 2006, 02:42:42 am »
Thanks man
Kevin
