Author Topic: new dumb question :) Figured it out  (Read 1562 times)
Lon
  • Last login:March 31, 2006, 04:32:00 pm
« on: March 06, 2006, 10:49:03 pm »
Ok, I am a complet newb and have proven myself to be a moron at times as well :)  That being said I would like to change the shift button on my Ipac4 from the player 1 start to a seperate button. I know this must be easy, but i can not figure it out. What keycode do you use to assign the actual shift button? I thought maybe shift would make sense, but apparantly I was wrong, or I am doing something way wrong. So far all I have managed to do is lose the shift abilty completley.
  Thanks for any help :)
Lon
 Heh, I see that if I go in to table view I can reassign the shift key.. Doh!
« Last Edit: March 07, 2006, 02:22:10 pm by Lon »
rwhip41
  • Last login:April 04, 2006, 12:46:36 am
Re: new dumb question :)
« Reply #1 on: March 06, 2006, 11:18:25 pm »
Lon,
Have you installed the IPAC Configuration Utility software that came with your card? It's really helpful in terms of customizing buttons and such. There are two ways to manipulate button settings within this software.  I personally find it easier to use the "Table" version (versus the button layout version)...you will see small check-boxes as to how you want to see the layout. From there (the Table), you can easily assign key assignments.
I would create a new IPAC file when in this Utility to mess with. Depending on what frontend you use, you should be able to launch this IPAC file with the frontend.
Regarding your wanting to change the shift function...what are your reasons for doing this? Do you want to change this because you want to set up individual buttons to allow for the use of the Pause, Escape, Tab, and Enter functions?
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: March 07, 2006, 08:53:39 am »
That's not a new dumb question ;)
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #3 on: March 07, 2006, 11:13:22 am »
You're going to fit in perfectly here  ;D
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
Lon
« Reply #4 on: March 07, 2006, 12:16:11 pm »
Lon,
thanks for the reply. yes I have installed the software and have been able to program all of the buttons EXCEPT for a shift button. I want to change the shift button to an independent button so that I can use player 1 and player 2 start buttons as shifted buttons so they can also be coin buttons.
lon
