Author Topic: strange dreamcast controllers (hackable?)  (Read 3065 times)
Seven7
  • Last login:March 26, 2016, 12:12:36 pm
  • Another golddigger, lets see how much i'am worth!
« on: February 07, 2006, 06:51:06 pm »
Just wondering if anyone has seen these before and if they can be hacked for arcade controlls.  I've never seen these before, although it whouldn't surprise me if someone else had.  Btw, they look cheap, a website i found has them for $2.99 each.   Your thoughts?
-Seven7-
"For what you Dream of..."-Virtual On Oratorio Tangram
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
Re: strange dreamcast controllers (hackable?)
« Reply #1 on: February 08, 2006, 08:31:30 am »
Well, I had bad luck with mine (different brand as yours) because they didn't have a common ground.
For 2.99 it's worth the experiment I think ;)
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
Seven7
« Reply #2 on: February 08, 2006, 04:45:54 pm »
Iam guessing yours was the astropad?  From what i can tell even if a pad dosen't have a common ground, its still hackable, just that it takes more time and wire.  I think ill wait for a few more opinions before makeing an order.
-Seven7-
dennis808
« Reply #3 on: February 08, 2006, 05:55:47 pm »
This was my post (and my pad).
http://forum.arcadecontrols.com/index.php?topic=41553.msg379238#msg379238
It's a perfectly hackable stick, but then for DC use only, and I have a multi-machine setup in my cab so :(
Seven7
« Reply #4 on: February 08, 2006, 07:02:50 pm »
just a note, they are not the same controller, still, your right.  Anyway, iam not doing this for a cab, but for arcade sticks.  Mvc2 and power stone 2 don't feel right without em.!
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #5 on: February 08, 2006, 07:05:58 pm »
Stop researching and just buy a few..
Honestly, its worth 3 bucks just to rip them apart and check..
  • Last login:Today at 11:57:52 am
« Reply #6 on: February 09, 2006, 05:48:06 am »
The astropad is hackable...  if you don't mind not having your L and R triggers, and a lack of a common ground.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #7 on: February 10, 2006, 05:50:20 pm »
And for what it's worth, the controller pictured is not an Astropad.
-pmc
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #8 on: February 11, 2006, 04:02:27 pm »
Easiest controllers to hack are the Sega ones. Thats what I used to do when I sold them. Just brush up on the soldering skills and get a nice thin iron tip and you should be good to go. Just make sure you get something pointy and sharp to scratch the contacts with and the connection should be good. If you want, I will send you a picture of mine when I get home later tonight for some ideas.
« Reply #9 on: February 11, 2006, 05:12:58 pm »
I also still offer my hacking service...   ;D
Goz
  • KOTA
« Reply #10 on: February 13, 2006, 09:36:17 am »
-= FYI =-
HarumaN hacks rule... can't go wrong with the quality and service.
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #11 on: February 14, 2006, 08:12:28 am »
-= FYI =-
Absolutely true!  HarumaN rules!  Thanx again for the hacked pads!  :)
markrvp
  • NFL Expert
« Reply #12 on: February 14, 2006, 03:30:04 pm »
I got my hacked pads from HarumaN yesterday.  I hooked the first one up last night and it worked perfectly.  Thank you for the valuable and reasonably priced service!!
« Reply #13 on: February 14, 2006, 04:36:14 pm »
Wow!  Thanks for all the praise, people.  I'm glad my hacks are working out for you.  :)
