Author Topic: Is this Dreamcast pad hackable? [edit: not completely]  (Read 3204 times)
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« on: August 14, 2005, 08:24:58 pm »
I got a hold of three cheap Dreamcast joypads (Nyko DC Commander):
And having some trouble figuring out where to solder them.
Here is a picture I took with yellow spots on it where i think I should solder the button-wires, I have no idea if this is correct though. ???
Can anybody enlighten me?
« Last Edit: August 23, 2005, 02:59:17 pm by dennis808 »
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re: Is this Dreamcast pad hackable?
« Reply #1 on: August 15, 2005, 12:36:52 am »
Those are the correct solder points.  The only trouble you may encounter is multiple grounds.  You can't really tell if there are multiple grounds by looking at a picture.  So you can either test for multiple grounds, do the hack and give it a try or find some one who has tried hacking these before.
Good luck!
dennis808
« Reply #2 on: August 15, 2005, 05:01:31 am »
...you can either test for multiple grounds
How would I do that? Just by multi-metering all the grounds and check if they meet?
And if i Would happen to have multiple grounds, is it then still possible to connect the dreamcast buttens to my control panel, which only has one (common) ground?  ???
TalkingOctopus
    • My Arcade
« Reply #3 on: August 15, 2005, 05:09:28 am »
  • Last login:Yesterday at 04:39:53 pm
« Reply #4 on: August 15, 2005, 06:05:42 am »
Yeah, I'd like to know the results of that as well.   8)  As it stands now, the only DC pads I use for hacking are Sega officials or the MadKatz.
dennis808
« Reply #5 on: August 22, 2005, 06:08:06 pm »
too bad fella's...
I measured 4 diffferent grounds...
Is it really impossible to hack?
skid_68
  • Last login:December 29, 2022, 07:25:30 pm
  • Hmmmmmmmm....
« Reply #6 on: August 22, 2005, 07:24:44 pm »
No, just means more soldering. Daisy chain all the grounds together.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #7 on: August 22, 2005, 07:48:20 pm »
Now how exactly would daisy-chaining all the grounds together be helpuful? I did that once with a two-ground board and the results were spectacular. It's like someone else is playing the game for you!
Dennis, I think that if you keep each of the 4 grounds isolated just like they are on the PCB, you can wire up a dedicated control panel. It'll work fine. But you won't likely be able to use the control panel with another controller or keyboard scanner without recombining the grounds back together to a single common ground.
-pmc
TalkingOctopus
    • My Arcade
« Reply #8 on: August 22, 2005, 10:05:11 pm »
-pmc
Yeah...I agree with what PMC said.  The controller is nearly useless for hacking :(.  Thanks for letting us know the results!
dennis808
« Reply #9 on: August 23, 2005, 09:25:51 am »
I made a small mistake while measuring, it has 3 grounds. :-\
But I can probalbly still make someone happy with a stand alone Dreamcast controller like the ones on this page:
http://www.darkravenwind.com/cdvision/images.htm
It's not impossible to wire...
Well, I guess I'll just have to sacrifice the original pads then, if I want my switching control panel to work.
Here's a really quick sketch of what I intend to do:
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #10 on: August 23, 2005, 11:49:56 am »
Nice illustration.  Yep a db25 switchbox will do the trick for you.  Don't forget you will need another switchbox to switch the video/sound between the PC and DC, and then you'd be all set.
dennis808
« Reply #11 on: August 23, 2005, 02:58:47 pm »
I have one of these connected to the SCART input on the back of the TV:
The machine that's on will be displayed on the TV, so it's a matter of turning the PC and DC on or off.
