Author Topic: Weird problem with I-Pac 2 and pushbutton  (Read 1788 times)
KungFuJoe
  • Last login:February 05, 2006, 05:10:10 am
« on: February 02, 2006, 06:19:16 pm »
Everything works fine with my ipac except for one button.  The problem with that is that it only "registers" when you depress and let go of the button.  Basically, when I push it down, nothing happens, but when i let go it registers a keystroke.  I know it sounds like something wrong with the button/switch or that I have the wire connected to the wrong lead on the switch but I confirmed that everything is wired to the right spot and I even tried replacing the switch.
If I open notepad or some text editor and hit that button, nothing shows up when I push it down (as expected) but when I release it...TWO characters show up...it reacts like I hit it twice really quick.
And lastly...during some 2 player simultaneous games (like R-Type Leo, etc) whenever Player one starts up in the middle of the action, it will sometimes "freeze" all of Player 2's controls for a second or two.
Anything I should be looking for?  Could it be the IPac itself?
« Last Edit: February 05, 2006, 05:01:56 am by KungFuJoe »
Re: Weird probably with I-Pac 2 and pushbutton
« Reply #1 on: February 02, 2006, 06:34:52 pm »
Sounds like you have the wire on the wrong prong to me.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #2 on: February 02, 2006, 10:47:20 pm »
Either connected to a NC instead of a NO or it's the SHIFT button (default player 1 start).
As with all Ultimarc problems, send it to Andy. He's helpful, thorough, and he checks his email every day.
KungFuJoe
Re: Weird problem with I-Pac 2 and pushbutton
« Reply #3 on: February 05, 2006, 05:03:10 am »
It's definitely not connected to the wrong prong...that was the very first thing that came to mind and I tried both prongs and another switch just to make sure...
I will email Andy though...
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: February 05, 2006, 05:26:12 am »
I would assume the offending button is Start1. This is the shift button by default and sends the keycode on release. But is should not send two presses nor cause a delay. Hopefully we can resolve this by email.
Andy W
