Author Topic: Disassembling a Suzo stick  (Read 1177 times)
f00ge
  • Last login:February 05, 2011, 06:07:05 am
  • Arcade builder 'virgin'
« on: January 18, 2006, 03:16:20 pm »
Hello all,
I'm trying to replace the spring on this Suzo stick.
But I'm having trouble removing that little disc-shaped thingie that holds the spring in place at the bottom of the stick itself.
When I did this with my X-Arcade stick, I simply pressed down slightly and moved the disc with a small screwdriver.
But on the Suzo it's really, really stuck. I don't know how to remove it without actually destroying the disc (and possibly more).
Anyone here seasoned with taking apart Suzo sticks?
Thanks,
Grasshopper
Re: Disassembling a Suzo stick
« Reply #1 on: January 18, 2006, 04:18:04 pm »
Unfortunately, it's very difficult without a special tool like this.
http://www.maplin.co.uk/Module.aspx?ModuleNo=4228&criteria=circlip&doy=18m1
f00ge
« Reply #2 on: January 18, 2006, 08:42:31 pm »
Hmm yeah, looks like I will need to get some of those. :x
Do those pliers work like inverted? The opposite if normal ones (you press and the 'claws' expand)?
Any more surprises waiting for me when I finally get this stick open? :D
Level42
« Reply #3 on: January 19, 2006, 06:16:27 pm »
Lars, you got it, this is indeed how they work.
At least the type Suzo uses are MUCH easier to handle than the "regular" E-clips, as long as you have the tool  ::)
You definitly need one of those to do it the "easy" way....take a look at this thread: http://forum.arcadecontrols.com/index.php?topic=41571.0
Good luck !
