Author Topic: Refresh + A great big hello  (Read 1965 times)
CptDoom
  • Last login:February 09, 2003, 12:49:37 am
« on: February 09, 2003, 01:00:27 am »
 :o  What a great place! Anyway hello, im building a mame blabla, just preparing u for the onslaught of questions seeing as ive registered.
May aswell start as i mean to go on. Im running xp and a ti4400 with a tv out to 29" trinitron that im going to be sticking in my cabinet, i have checked to see if it works and it sure does, apart from MAME, iim thinking its the refresh rate. Also what program do u use to output the picture to tv, im using tvtool atm (demo) so it cuts out every 15 minutes which is useless, is there a better way to do thjis?
Any help for this hardware n00b/rom genius ;) would be gratefully received
wescotte
  • Last login:September 15, 2004, 01:16:15 am
  • I'm a llama! I didn't want to change it
Re:Refresh + A great big hello
« Reply #1 on: February 09, 2003, 04:38:09 am »
You can just simply go into your display properties and enable TV output. No need for TV tool.
Eric
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #2 on: February 09, 2003, 05:23:46 am »
Your geforce4 should be able to just send the tv signal out your svideo/comp port on your card independantly of software.  My geforce2 does that.
