Author Topic: LEDWiz Client Driver Beta DLL Available  (Read 12100 times)
MikeQ
« on: January 12, 2006, 10:55:09 pm »
For all those following the blinky lights LEDwiz - www.GroovyGameGear.com thread, here is the LEDWiz client driver DLL for all you programmers who want to write programs to control LED's.
pointdablame
Re: LEDWiz Client Driver Beta DLL Available
« Reply #1 on: January 13, 2006, 01:18:03 am »
I saw that video and really love it.  I just wish I could program my way out of a wet paper bag.
Hopefully someone will make an idiot proof program to get this kind of stuff running, otherwise I fear I'll have a hard time getting it all to work together.
My next panel will have translucent buttons and LEDs, so a simple way to make them light up all purdy like sure would be cool, especially lighting up the active buttons in games like your video shows.  I can't wait to see what some of you guys come up with.
first off your and idiot
MikeQ
« Reply #2 on: January 13, 2006, 08:03:49 am »
« Last Edit: January 13, 2006, 08:33:36 am by MikeQ »
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #3 on: January 13, 2006, 08:41:42 am »
Let's say I'm an idiot that hasn't programmed since Amstrad Basic (don't laugh). If I were to spend some time learning a little Visual C# (Express Edition), do you think I could actually do something with this? Is there a particular area I should focus on? Or would it require too much effort on my part?
Right now I can only dream of a Winamp plugin style app that syncs LED patterns to a detected beat. That would be pretty sweet to run behind a frontend. I know there's a beat detection dll out there, but it's useless in my hands.
MikeQ
« Reply #4 on: January 13, 2006, 09:38:05 am »
I'd look at Winamp and see how plugins are made for that.  You could take a winamp pluging that does an equalizer or some affect based on the beat and instead of creating a graphic output of this, create an LEDWiz sequence.
  • Last login:Today at 02:27:29 am
« Reply #5 on: January 13, 2006, 02:27:56 pm »
How beat detection programs work is quite simple, it's just the doing it part that's hard.
Instead of opening the music file once, it is opened twice... once for listening, and another time (at a much lower sample rate) for beat detection.  As the music is playing, the low sample version is literally read a chunk at a time as music files use a numeric value to determine the frequency height.  This number is then normalized and converted into something useful (like a value from 0 to 100) and this value is then, in-turn used to adjust something graphically.  Of course what you do with that number is up to you.
I don't know if you'll find any of that useful, but I thought I would try.
HAC
MYX
  • Last login:September 18, 2020, 05:00:22 pm
  • Even Jesus loves Donkey Kong!
    • MYX Digital Blog
« Reply #6 on: January 14, 2006, 06:29:27 pm »
Mike,
I am very interested in playing with this. I am in the process of building my cab and have been playing with the LEDWiz software, but have not purchased it yet. I wanted to see how it shaked out first. What I saw in the video, do we just download the dll and put it somewhere (like we do with roms) and it works or is there more involved? When it is attract mode, does it go out and find an animation made with the LEDWiz? Did you have to tell the it which buttons to light per game or does it look at the cfg files?
Nice work BTW.
M    Y    X
BLACKOUT  - Finally rewritten - http://blog.myxdigital.com/
Original BLACKOUT thread - http://forum.arcadecontrols.com/index.php?topic=48239.0
MikeQ
« Reply #7 on: January 15, 2006, 01:11:10 pm »
Mike,
Nice work BTW.
This DLL is for programmers who want to program the LEDWiz directly.  This doesn't make MAME do the attract mode or the control lighting.  I use a custom version of MAME to do the control lighting and attract mode.
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #8 on: January 22, 2006, 01:55:56 pm »
MikeQ,
Can this dll be referenced directly from VB6 or VB.net or does it need a com wrapper? I'd definitely like to use it but my C skills are limited.
Robots will kill you.
Arcade Addiction
MikeQ
« Reply #9 on: January 22, 2006, 10:23:49 pm »
I would just use RandyT's OCX control if your are using VB.
MikeQ
« Reply #10 on: January 28, 2006, 06:28:51 pm »
NEW!!!  LEDWiz.dll version 1.0.0.1 is now available!!!
The new dll supports differently ID'd LED-WIZ's for multiple devices on a single machine.
Up to 16 are supported.  Contact www.groovygamegear.com for the specially ID'd devices.
This dll also introduces hot swap capability so you can unplug your LED-WIZ device while in use.  Upon plugging them back in they will pick up and continue their lighting sequence.
This is nice for USB control panels that can be switched out without restarting MAME.
Download the new driver, test program to show how to use the DLL and source for the test program here:
LEDWiz_DLL_Beta1.1.zip
*note, this dll is not backwardly compatible as the API has changed.  You will need to recompile against the new dll.
« Last Edit: January 28, 2006, 06:32:20 pm by MikeQ »
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #11 on: January 28, 2006, 10:15:40 pm »
Nice job, MikeQ!  I guess I need to order up another LEDWiz. ;)
MikeQ
« Reply #12 on: January 28, 2006, 10:49:23 pm »
Now that I've got two, I'm trying to figure out what to do with all the extra outputs.  The second one is dedicated to the cabinet.  The first one is only for the CP.  Not sure where I'm going to put all the cabinet lights yet.
arzoo
    • LEDBlinky
« Reply #13 on: June 16, 2006, 10:39:01 pm »
Mike,
Any chance you can do a VB wrapper? Randy's OCX does not control multiple LEDWiz's.
Arcade Addiction
