Author Topic: Ultimarc Question  (Read 1002 times)
loremtr
  • Last login:May 19, 2007, 01:15:16 pm
  • Woo hoo..finally building a cabinet.
Ultimarc Question
« on: January 02, 2006, 04:17:18 pm »
Im using the ultimar setup program to confirm my button wiring.  Everything is working fine except the joysticks and P1B1.
The joysticks are regstering that they are pushed in multiple directions...when the joysticks are being pushed.  Its almost like they are stuck...however I checked the microswitches and nothing is touching them.    Any ideas?
jcrouse
    • CPViewer
Re: Ultimarc Question
« Reply #1 on: January 02, 2006, 04:25:01 pm »
Do you have the connectors on the correct lead on the switch. It sounds like you have the one lead switched between normally-open and normally-closed.
John
loremtr
« Reply #2 on: January 02, 2006, 04:39:19 pm »
ok..joystick problem fixed....
Still have the P1B1 firing whenever I press up on joystick 1 though.
