Author Topic: LED wiring question  (Read 1653 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
LED wiring question
« on: September 21, 2005, 09:44:36 am »
In my mind I think this should work but the paranoia of blowing a motherboard causes me to ask... Will this wiring set up work?  Is this basically a parallel circuit even though the LED leads are connected to a common point?
wintermute
  • Last login:December 01, 2006, 09:04:25 am
  • Whip the thugee guards.
Re: LED wiring question
« Reply #1 on: September 21, 2005, 10:11:45 am »
Looks like it should work fine to me.
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« Reply #2 on: September 21, 2005, 10:56:00 am »
Its looks valid.
Teamwork - A group of people running around doing what I say.
commandcom
  • Last login:February 11, 2006, 11:56:19 am
« Reply #3 on: September 22, 2005, 12:42:40 pm »
You might also consider getting one of these:
http://www.gamecab.com/products.asp?cat=26
ROMbler
  • Last login:December 01, 2025, 10:51:49 pm
« Reply #4 on: September 22, 2005, 02:26:51 pm »
It'll work no prob. - I was just wondering what your plan is for them?  I'm always looking for good mod ideas
KonkeyKong
« Reply #5 on: September 22, 2005, 02:43:47 pm »
nothing new, I'm using them for a Knievel lighted button mod. Once I saw The NeonMame I just haven't been the same since.
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
« Reply #6 on: September 23, 2005, 12:24:39 am »
Its fine..   Why the 12v rail, though?  They'd be better off on the 5v rail, imo, since hardly anything else will be using it..
Not like LEDs draw an appreciable amount of power..
KonkeyKong
« Reply #7 on: September 23, 2005, 09:32:02 am »
12 volts will also be running the neon speaker rings and coin door lights so I thought I'd just run the LEDs off of that feed as well.
TOK
  • The Game Always Wins
« Reply #8 on: September 23, 2005, 02:19:22 pm »
I'm not sure why anyone bothers with the resistor setup. You can buy pre-made 12v LEDs at most automotive stores. A 3 pack is under 5 bucks and they're very bright.
