Author Topic: Another 49-way question  (Read 853 times)
fiscap
  • Last login:November 24, 2024, 03:30:36 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« on: September 08, 2005, 05:44:15 pm »
Does anyone know how much depth you need in your control panel in order to install a 49-way joystick? I checked the specifications on the Happ site and there are no dimensions provided.
RandyT
    • GroovyGameGear.com
Re: Another 49-way question
« Reply #1 on: September 08, 2005, 09:32:45 pm »
You're going to want at least 3.25" below the bottom surface of the panel.  If you intend to ever replace the shaft with one of our ball-tops, go 3.5"
If you want to use floyd's rotary adapter, you'll need quite a bit more.
RandyT
