December 02, 2025, 07:49:49 pm
Two monitors?
Hi guys,It seems that time crisis is to be emulated by mame soon.
Quote from: PedroSilva on August 19, 2005, 07:24:02 pmHi guys,It seems that time crisis is to be emulated by mame soon.Soon?
Quote from: RayB on August 19, 2005, 08:13:27 pmTwo monitors?two monitors being, on time crisis II and newer the 2 player setups had either a sindle (SD) or dual (DX) monitor setup. allowing for much larger play area in the arcade version. Basically his question is, will the mame'd time crisis be able to do two monitors. And for a guess I would say, proly not.
Quote from: Pik4chu on August 19, 2005, 08:51:56 pmQuote from: RayB on August 19, 2005, 08:13:27 pmTwo monitors?two monitors being, on time crisis II and newer the 2 player setups had either a sindle (SD) or dual (DX) monitor setup. allowing for much larger play area in the arcade version.
Quote from: JB on August 21, 2005, 02:14:42 pmQuote from: Pik4chu on August 19, 2005, 08:51:56 pmQuote from: RayB on August 19, 2005, 08:13:27 pmTwo monitors?two monitors being, on time crisis II and newer the 2 player setups had either a sindle (SD) or dual (DX) monitor setup. allowing for much larger play area in the arcade version. Basically his question is, will the mame'd time crisis be able to do two monitors. And for a guess I would say, proly not. It doesn't allow a larger play area. It allows 2 players. And as far as I know, it's actually 2 totally seperate machines in one cabinet.sora mispoke myself, what I meant by larger area is just that two players dont have to share the same monitor and stand so close to each other.[/qote]Ah. Also gives each player a first-person view of the action. If they shared a screen, they'd have to use the same viewpoint.QuoteAnd it is my understanding that the arcade cabs were just a single board specially designed for two monitors/guns/players. But since Ive never seenm inside one I cant be sure. Though it doesn't really matter *shrugs*I thought it was 2 boards, but I may very well be mistaken.It may turn out to matter, though. If it uses 2 boards with one driving each screen and a comm cable connecting them, the cost to emulate goes way up over the other System 23 games.
