Author Topic: Artwork Feedback needed (see newest post)  (Read 6663 times)
digitalpackrat
  • Last login:April 20, 2013, 07:05:52 pm
  • Cabinet currently in progress
« on: August 12, 2005, 11:30:37 am »
This is my first attempt at creating my marquee.  Any feedback/suggestions would be appreciated
fullsize here ->
http://www-personal.engin.umd.umich.edu/~echapiew/marquee%20first%20attempt%20middle%20adjusted.jpg
« Last Edit: May 28, 2006, 10:08:15 am by digitalpackrat »
ViriiGuy
  • Last login:January 08, 2020, 12:30:46 pm
  • Terminus clone build in progress.
Re: marquee first attempt. suggestions?
« Reply #1 on: August 12, 2005, 12:06:24 pm »
It looks good, but I would work on the blending a little. and you have several spot where a stray color is bleeding thru. Those will REALLY show up when you print it.
But I like it.
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #2 on: August 12, 2005, 12:08:18 pm »
Colorful.  The whip on the left needs to be blended better, it has white edges.  I always hate that (and never have a good program to fix it.)  I assume this is a fighting cab.  No MAME in the logo?
digitalpackrat
« Reply #3 on: August 15, 2005, 11:24:05 pm »
thx for the comments.  As for blending the colors I'm new to using paint shop pro (using version 9) any tips on how to do that would be great.  also i wanted to maybe wrap the text around the circle item in the middle but could not figure out how to wrap text.  any PSP experts out there know how to do that?
As for the mame logo,  this cab is going to be an all inclusive cab having not just mame, but emulate all the older console systems from n64 and back as well as have a DC, PS2, PS1, and X-box systems in the arcade (i'm using the x-arcade controls I stripped apart and put into a 4 player housing with golden-tee trackball.  So singling out mame is not a high priority
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #4 on: August 16, 2005, 12:03:34 pm »
I've got a suggestion.......  Where's mine.  ;D
That looks really crisp.  Good Job.
digitalpackrat
« Reply #5 on: August 20, 2005, 09:45:39 pm »
thx for the compliments.
Anyone know though how to wrap the text around the circle object in the middle with paint shop pro or know of another program which i could use to do that?  I do have photoshop but know less about that than PSP.
Also any tips on how to blend the layers?
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #6 on: August 21, 2005, 05:11:26 pm »
I think that's bad ass!  I agree about the white bars on the side...those need to go..but I'm not really seeing these colors bleeding through (although admitadly I don't know what I'm looking for)  If I knew that maybe I could help.
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
AtomSmasher
    • Atomic-Train
« Reply #7 on: August 23, 2005, 02:29:58 am »
That is one sweet looking marque.
digitalpackrat
« Reply #8 on: August 23, 2005, 05:44:42 pm »
Took me awhile playing around with PSP but I finally figured out how to wrap text, though I decided wraping it real close to the middle circle layer didn't look good.  Here's a modification to the original.  I made the middle circle layer a little smaller in order to make the arcade name a bit larger, wraped the Unreal a little in order to make it a bit larger as well and got rid of the white stripes on the sides
Does it look better with the wrapped "Unreal" Text or straight?
Link to larger version
http://www-personal.engin.umd.umich.edu/~echapiew/marquee%20first%20attempt%20middle%20adjusted3.jpg
« Last Edit: August 23, 2005, 05:53:12 pm by digitalpackrat »
digitalpackrat
« Reply #9 on: August 23, 2005, 05:53:52 pm »
Here's a side by side of the 2
  • Last login:Today at 11:49:10 am
« Reply #10 on: August 24, 2005, 03:26:37 pm »
I like the wrapped version better but I also think you should shrink the green circle in the middle and make the font on "unreal" a little bigger and have it overlap the green circle a little.
digitalpackrat
« Reply #11 on: August 26, 2005, 04:57:50 pm »
Are you suggesting making the circle even smaller than what I have already shrunk it?  Here it is with your suggestions with an even smaller circle
« Last Edit: August 26, 2005, 05:02:25 pm by digitalpackrat »
digitalpackrat
« Reply #12 on: August 26, 2005, 05:10:39 pm »
Here is the side art I've been playing around with.  I posted this a few months ago but got caught up in school and wasn't able to check up/reply on any suggestions so comments would be great
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« Reply #13 on: August 26, 2005, 07:34:19 pm »
Looks good! But how do you plan to stick it on the side ? Personally I dont like square sticker. Either put it in as a logo (kind of... maybe with stroke around it, and not making it square) or put it as big as you can covering the whole side.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #14 on: October 05, 2005, 10:44:00 pm »
On the marquee-
I recommend losing the green circle and putting the U unreal logo there instead.
I would also erase the blocky ice frost around Sub Zero's hands and just paint in some yourself, it will look much better.
On the side art- nice idea, but the characters in the clouds need to blend better.
digitalpackrat
Continuing my artwork
« Reply #15 on: May 28, 2006, 10:05:34 am »
Ok its been nearly a year since I completed my cab and have not finished the artwork.  Finally found some time this weekend to attempt some suggestions from earlier and could use some feedback.
I've decided to try and make it more of a rectangle poster shape instead of a square, but by doing that some of the characters had to go.  I've made a few different versions, some with the characters at the top, some with the name of the cab and with completely new backgrounds that match more closely the color of my control panel.  Final Picture is the cabinet nearly completed ( still need to finish the doors on the front and put in my coin doors) and you can see the personal printer marquee and sideart I printed, definently need to get it professionally printed
« Last Edit: May 28, 2006, 10:17:53 am by digitalpackrat »
digitalpackrat
Re: Artwork Feedback needed (see newest post)
« Reply #16 on: May 30, 2006, 07:17:42 pm »
any suggestions?
melidian
  • Last login:August 01, 2009, 09:24:38 pm
  • Me So Happy...Me Want To Cry.
« Reply #17 on: June 14, 2006, 09:05:33 am »
you could cut it down the middle and make 2 cabs?  :laugh2:
i love the fishes cause their so delicious
digitalpackrat
« Reply #18 on: June 15, 2006, 09:45:02 pm »
I've decided to go with the jungle background because it goes more with the color scheme of my cab but the longer I wait to print it the more I keep playing with it.  I've decided not to go with the words at the top.  added more characters.  does it look better with the additional characters or  does it make it too busy?
« Last Edit: June 15, 2006, 09:47:32 pm by digitalpackrat »
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #19 on: June 16, 2006, 10:00:21 am »
Actually, I think it would look better if all of your characters weren't clustered at the bottom of the image. But I guess it's better that than to show them with no feet, etc.
Make your cabinet look its best with custom art from
Gamecreature!
