Author Topic: What to use for Trackball hole in Lexan?  (Read 1579 times)
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
« on: July 24, 2005, 04:13:48 pm »
hello all,
i'm at a stage where i'm working on my CP lexan. i was able to drill all the button holes fine, but now i'm at the trackball hole.. how should i go about making this hole in the lexan? router??
thanks in advance..
Bones
  • [Moderator]
Re: What to use for Trackball hole in Lexan?
« Reply #1 on: July 24, 2005, 05:12:31 pm »
I used a holesaw to drill the trackball hole into the Lexan then did another hole the same size into some scrap MDF. I then put the Lexan over the MDF and lined everything up and used the bottom layer of MDF as a guide to put a nice edge on the Lexan using a router.
It worked well. Check Arcade Bones in project announcements for final trackball hole finish.
Elfman
  • Last login:February 01, 2012, 05:58:11 pm
  • Cabinet done! CP Done! Just tweaks left to do.
    • My Corner of the World
« Reply #2 on: July 25, 2005, 01:06:28 pm »
I drilled a starter hole in mine and then used my router with the flush trim bit and the trackball mounting plate as my guide.
Worked well in my application.
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #3 on: July 25, 2005, 02:33:30 pm »
I did the same with the router and spare MDF and came out fine. I also used a bevel bit afterwards to round the whole so it was nice and smooth...
The Way Back Machine - http://www.taborious.com
