Author Topic: Looking for advice on my 4-player & 2-player cp designs  (Read 1460 times)
wallyworld
  • Last login:October 19, 2007, 01:55:54 am
  • Moose outside should've told ya.
« on: July 21, 2005, 03:15:49 am »
Hi, I'm looking for advice on control panel layouts I designed.
"I think, therefore I drink."
Tiger-Heli
    • Tiger-Heli
Re: Looking for advice on my 4-player & 2-player cp designs
« Reply #1 on: July 21, 2005, 07:13:17 am »
Consider swapping the 3" trackball and 4-way E-stick positions.  This give more symmetry for marble madness and puts the 4-way front and center for Pac-Man, etc.  (Worse for golden tee).
Not sure how different size trackball will affect 2-p Marble M. . .
Hopefully others will be more helpful.
wallyworld
« Reply #2 on: July 22, 2005, 03:15:24 pm »
I like your thinking there.  I'll see if I can make that work.  My guess is that that 4-way stick is going to get the most use (compared to the spinner and trackballs), so it really should be centered up more.
Thanks for the input!  Anyone else?
NoOne=NBA=
« Reply #3 on: July 22, 2005, 03:36:25 pm »
space-permitting, also plan to include analog joystick on this panel to play Tron, and most other analog joystick games.
Tron doesn't use an analog stick.
It's a modified 4-way top-fire, that will barely hit the diagonals.
The restrictor on it keeps it from acting as a TRUE 8-way, which prevents zig-zagging in the lightcycle stage.
With the exception of a 49-way, with a GGG adapter, Tron will not play well with any other single stick.
You can program a 4-way, and an 8-way to control the game simultaneously however.
That will let you pick which stick to use on which stage, allowing 4-way only in the lightcycles, and 8-way in the other stages.
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« Reply #4 on: July 22, 2005, 05:01:58 pm »
2 cents worth:
From what you are showing on the 4 ply panel,
dont put items smack up against the wood
sides that will be underneath... meaning your buttons up on top...
make sure they have a LITTLE more clearance than
a 'close fit'
« Last Edit: July 22, 2005, 05:15:48 pm by daveg2000 »
...so I will ask you... "Deal, or No Deal?"
