Author Topic: Adding plexi to already made CP.  (Read 1257 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: July 20, 2005, 10:34:26 am »
Hello,
I have a cabinet that has been done for a few years now, and I am looking to enhance it.  I really want to add artwork and plexiglass to the CP.  Currently it is 3/4 MDF which is laminated.  I have T-Molding around the edges of the panel.  My quesion is, if I were to add artwork on top of this, and then a layer of plexiglass, 1.  Would this "feel" right with the edge being just above the T molding (it "seems" to be level now) and 2.  How do you drill the holes in the plexiglass?  Thanks in advance!
ED7
xonix_digital
  • Last login:February 20, 2016, 04:36:05 pm
  • I am the Milky-Way Commander!!!
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
Re: Adding plexi to already made CP.
« Reply #2 on: July 20, 2005, 10:45:44 am »
I did the same thing just recently.  And I used lexan too - well that's what the shop made for me.  Let's just say my CP is heavy now!
I made a digital template of my CP (the old fashioned way - I measured it then drew it on my PC!) then I had to get that printed several times until it matched up correctly.  Then I could use that to get the lexan and the CP artwork done.  And I don't think it looks bad at all!
I've noticed several games in my local arcade that have the lexan/plexi whatever above of the t-molding.  Just smooth down the edges and I don't think people will complain.
stevodevo
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #3 on: July 20, 2005, 11:06:23 am »
You could just replace that t-molding with some 7/8" to make up the difference.
electricd
  • I'm not a llama!
« Reply #4 on: July 20, 2005, 11:09:00 am »
Didn't know they made such a thing.  That would be probably the best idea for me.  Now to find someone to lay the graphics out for me! (i am graphically challenged!)
stevodevo
« Reply #5 on: July 20, 2005, 12:01:18 pm »
that would work too...unless you already had the slot cut in your CP like I did... although I spose you could use the larger t-molding and just trim off the bottom! haha
my sis is a graphic design major so she did all my cab artwork!  she did mine free but i can ask her what she'd charge to do yours if you're interested...otherwise find a good artsy friend :)
electricd
  • I'm not a llama!
« Reply #6 on: July 20, 2005, 02:13:19 pm »
Im interested!
Knievel
    • Knievel Kustoms
« Reply #7 on: July 20, 2005, 02:27:57 pm »
