Author Topic: New CP layout with usb ports  (Read 1346 times)
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« on: June 23, 2005, 09:44:42 am »
Was looking into building a new panel and adding USB ports. Also keeping them kinda hidden. Now my cab sits in a corner so the area of the cp I want to put them is kinds hidden. I also went as far as to add the mouse or t-ball buttons to the player one and player 2 controls. Buttons will be the same color and no stand out difference. This is also just the frame the top will be the usual shape and have a bit of overhang. So please through some feedback or ideas. Don't want to build a new CP every year! :)
Not to scale!!!!
Franco
Re: New CP layout with usb ports
« Reply #1 on: June 23, 2005, 09:54:08 am »
You may want to move the 4-way and/or the trackball slightly so you dont hit your hand on the 4way.
USBs are a good idea, I intend to add a panel flush to the lower front of mine with a USB hub, 2 n64 ports and two ps2 ports at some point.
BarontheFirst
« Reply #2 on: June 25, 2005, 02:18:20 pm »
Just wondering but were I want to place the usb ports on the back side of my CP if anyone has also added there main power switch and pc power switch? If so should I just place a 4 gang electrical box there? I want to keep usb on both sides so it looks like I need about 6" overhang on each side. Again any tips or ideas would be great TY in advance all.
