Author Topic: Crown illuminated microswitch pushbuttons pre-orders  (Read 3039 times)
lseelba
  • Last login:November 15, 2006, 01:31:57 pm
  • You must defeat Sheng Long!
« on: June 10, 2005, 04:52:11 am »
I am ordering a limited number of Crown screw on illuminated microswitch pushbuttons, with a bulb (12V) that lights up the top of the button.  If you are interested the price is $3.55 per button.  These are standard size and will fit most predrilled panels.  Here are some pictures:
Thats a Deco microswitch (predominant Korean brand).  If there is enough interest I'll put in a big order in the future.
« Last Edit: June 13, 2005, 02:59:42 am by lseelba »
TOK
  • The Game Always Wins
Re: Any interest in illuminated microswitch pushbuttons?
« Reply #1 on: June 10, 2005, 10:12:10 am »
Those are neat. How much bigger are they than a standard button?
They look huge.
AlanS17
    • AlanS17
« Reply #2 on: June 10, 2005, 10:55:33 am »
I can't see a thing...
Got a link?
dweebs0r
  • Ascendo tuum!
« Reply #3 on: June 10, 2005, 11:26:04 am »
How about a picture of them mounted and lit so we can decide on colors.
Thanks,
-Dweebs
lustreking
  • Last login:October 11, 2021, 08:43:06 am
  • One Louder
« Reply #4 on: June 10, 2005, 01:02:38 pm »
Any chance you could get square ones too?
-Steve
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: June 10, 2005, 02:08:37 pm »
I'm interisted.
How much would they cost each?
« Last Edit: June 10, 2005, 10:10:41 pm by qbert247 »
Otraotaku
  • Last login:May 17, 2025, 05:38:18 am
  • トラビス
« Reply #6 on: June 10, 2005, 03:47:38 pm »
yes, me too  ;D
lseelba
« Reply #7 on: June 11, 2005, 03:25:29 am »
It would be a range depending on how many I order and how much shipping from Korea is, but each button would be between $4-$5.  Probably closer to the low end.
I found out that the bulb can be replaced with a 5V, meaning that you could run the bulbs with the output from a Dreamcast or Playstation 2 or whatever.  However the stock bulb is 12V.
The size of the button is pretty standard.  I believe the screw in part is 28 mm in diameter but I'll have to confirm that.  They should work in most predrilled cabinets.
The buttons sit a little higher than normal pushbuttons, but in Korea these are usually used in some puzzle/rhythm games (i.e. BishiBashi, Pop'n Music) and adult gambling cabinets (i.e. pachinko).
As for square buttons, I'm only doing round ones right now but I believe Happ has some square illuminated pushbuttons.
I'll have more pictures once I get the first test shipment in, but the pictures I have now can be found at: http://photos.yahoo.com/lseelba
AlanS17
    • AlanS17
« Reply #8 on: June 11, 2005, 04:02:31 am »
I'd sure like to see some pictures of those things once they're lit up.
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: June 11, 2005, 03:25:52 pm »
OUCH... that could add up quickly... Is there a discount for bulk order?
lseelba
« Reply #10 on: June 12, 2005, 03:39:28 am »
Yeah...like I said the pricing all depends on shipping from Korea.  I'll update here when I know more.
How much bulk are you talking about?  50+ and I can definitely get you a bulk rate.  I'll have pictures soon :)
arcadegeezer
  • Last login:April 04, 2010, 04:49:48 am
« Reply #11 on: June 12, 2005, 05:46:00 pm »
Hi
Have you seen the thread regarding shawnzilla's buttons on the forum ?
He is just setting up a site that is going to be doing all sorts of Tranlucent/Lit Buttons !
check his website:- http://www.fxbuttons.com/
they really do look great, might save you some money !
Cheers
Mark
lseelba
« Reply #12 on: June 13, 2005, 02:56:03 am »
UPDATE:
I'm getting a limited number of these from Korea as a test run.  If you want to pre-order them, the price is $3.55 per button.  This includes the button, the lamp assembly, the microswitch, and the nut.  Available colors are yellow, green, red, and blue.
Like I said, I will have a very limited number of these, so first come first serve.  I expect to receive the shipment in 10 to 15 days.  PM me or post here.
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
Re: Crown illuminated microswitch pushbuttons pre-orders
« Reply #13 on: June 13, 2005, 10:34:48 am »
Just an FYI.  You may want to consider using a lower voltage bulb or LED in these as the bulb that comes with them runs hot enough to make the plastic expand which in turn causes the button to stick.
Q*Bert_OP
  • Oh yes, we did!
« Reply #14 on: June 13, 2005, 10:53:42 am »
Are these suitable for gameplay buttons?
What kind of life cycle do the switches have?
