Author Topic: Sanwa harness pinout  (Read 5339 times)
Goz
  • KOTA
« on: May 19, 2005, 12:54:39 am »
I'm about to wire a couple of SANWA joys and was curious if anyone could tell me what the pinout is for the PC board on the joy. There are 5 pins so it makes sense that one pin is ground and the remaining 4 are up, down, left, and right but there are just enough possible combo's to make me want to have a beer and once that happens this panel will not get wired. Since i dont have the original harness it wont help to use color as a referrence.
Thanks,
-Goz
paigeoliver
  • Awesome face!
Re: Sanwa harness pinout
« Reply #1 on: May 19, 2005, 04:12:26 am »
Ground will almost certainly be the far left, or far right pin. Should take about 20 seconds to figure out with a multimeter (or you can just look at the traces), sorry I can't be more helpful, but I am at work right now and don't have access to my candy cab at the moment.
Goz
  • KOTA
« Reply #2 on: May 19, 2005, 09:22:27 am »
Paige,
 Thanks and I figured ground would be either position. I was hoping to get the full pin orientation from someone however as I'd like to the make the harness without needing to try each wire individually prior. If I could make the harness while I'm at work (when I have more spare time) as opposed to running through each wire with the wife insesently nagging in the background things would go far more smoothly.  ;D
Thanks,
-Goz
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: May 19, 2005, 09:26:21 am »
There's a more detailed thread about this somewhere... couple weeks old...
NO MORE!!
Goz
  • KOTA
« Reply #4 on: May 19, 2005, 09:29:57 am »
Of course you know I did use the search feature  ;D
Goz
  • KOTA
« Reply #5 on: May 19, 2005, 09:35:10 am »
I just searched again and I think I found the post you are referring to:
http://forum.arcadecontrols.com/index.php/topic,36561.0.html
And here is the answer:
 With the pins facing towards you starting from left:
ground
down
up
right
left
I'll hope that the guy who posted this info with just 1 post to his name was right. Unless anyone can confirm it's something different.
-Goz
