February 25, 2026, 02:48:18 pm
Total Members Voted: 43
That thing is the coolest but who the hell plays Space Invaders these days?
This place is dead lately. Stingray scare everyone off?
Don't suppose you want to take some meaurements of the cabinet for me?
You couldn't mount a mirror in the cabinet without a mirror, though. The dimensions of the cabinet prevent it.
I don't get the difficulty here.
I read somewhere that you should check the 10 UF electrolytic capacitors on the mainboard, right beside where the daughter board plugs inThere's like 4 of them or somethingIf that's all it is it'll be a cheap fix
Rick Adair wrote in message <3859d...@news.desupernet.net>...>Need some info on vid problem with SID. The video started getting garbled as>if it was losing sync. Then all of a sudden the vid just stop. I cleaned all>connectors and replaced all the fuses. No Luck. It almost seems like the>video isn't getting power. the game works other wise. I can coin up and get>sound and control just no video. Any help would be greatly appreciated..Sounds like you've lost the 10uF cap near the edge connectoron the motherboard.Alexhttp://home.neo.lrun.com/ayeckle/ayeck...@neo.lrun.com (Play)yeck...@diebold.com (Work)
I had a Midway one a few years back. Elektronforge.com rebuilt the boards and PS for me. It worked for 20 minutes and burned out the board. If you guys have a Midway version.........get your voltmeter and test of -5 Volts on the pcb!!! It needs it or it takes out board parts in a VERY short time. My wiring was dirty, and it took its toll that quicky. I am guessing thats what cooked it the first time, too.
Snipped this from a disscussion on another board. Not sure if this applies to you or not, but thought I'd pass it along:QuoteI had a Midway one a few years back. Elektronforge.com rebuilt the boards and PS for me. It worked for 20 minutes and burned out the board. If you guys have a Midway version.........get your voltmeter and test of -5 Volts on the pcb!!! It needs it or it takes out board parts in a VERY short time. My wiring was dirty, and it took its toll that quicky. I am guessing thats what cooked it the first time, too.-S
I can certainly check it out. I need a voltmeter, anyways. I need to see what parts of that machine are even getting power. I'm working blind.
Uh, did you look at the fuses or did you actually test them for continuity?
Good.
Read this.
