Author Topic: SlikStik Aluminium Spinner Top Colors  (Read 1061 times)
namedos
  • Last login:July 16, 2025, 07:15:23 pm
« on: March 01, 2005, 02:45:24 pm »
The primary colors for my arcade are red, black and dark grey.  I'm finding that I've got too many shades of red right now and I was curious if anyone has tried painting the SlikStik Aluminium Spinner Top?
I currently have the red aluminium top and it looks like a muted red rather than the bright red of the Ultimarc T-stick.
Did a search but couldn't find anything relating to painting aluminium.  If I do paint it would it be best to spray it?  I'm thinking there has to be some bright red at an auto supply shop.
Thanks.
whammoed
  • Last login:Today at 01:10:07 pm
  • Crack don't smoke itself
    • NiceMite
Re: SlikStik Aluminium Spinner Top Colors
« Reply #1 on: March 01, 2005, 02:53:36 pm »
Painting aluminum can be tricky.  I don't know if the anodized surface that the slikstik spinner knob has makes a difference.  Anyway you will likely need a latex based primer meant for aluminum which I have never found in a spray can. Then you can go over that with anything you want.  Even so you may have trouble with it coming off after a while of use.  Just spraying enamel spray paint directly on it will likely have adhesion issues.
This is my experience with the subject, maybe someone else will have a better plan for you.
Also, know anyone in the auto painting biz?  I bet they could put a durable finish on it.
Helmgar
  • Last login:August 31, 2015, 01:52:41 pm
« Reply #2 on: March 01, 2005, 10:59:38 pm »
If you check around some paintball shops can anodize them for you. They tend to work with smaller pieces than automotive shops, and should be able to give you a decent price
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: March 02, 2005, 09:02:39 am »
or you could acid etch and dye it which would give it a textured feel and color of choice.
