Author Topic: Analog Control/paddle for pong  (Read 1239 times)
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« on: February 19, 2005, 10:57:45 am »
OK, so my latest project is working with the AKI, using 100K pot for paddles in pong.  I have tried to adjust sensitivity, speed, but am having no luck.  The paddle will move but, just a little, not the full screen.  Does anyone have any ideas that I might try?  Or has anyone else tried working on this?  Is the pot OK to use for a paddle?
Help is much appreciated ???
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Analog Control/paddle for pong
« Reply #1 on: February 19, 2005, 04:54:49 pm »
I assume you adjusted things in Mame.
« Last Edit: February 19, 2005, 04:58:55 pm by JODY »
Minwah
    • MAMEWAH
« Reply #2 on: February 21, 2005, 05:41:01 am »
Calibrate the AKI in Control Panel > Game Controllers
IMMark
« Reply #3 on: February 21, 2005, 08:54:36 am »
Thanks, to both of you for responding.  I have a problem with the AKI board itself and am working with Dave.  Once I have a working board again, I will follow up if I still have setting problems.  But could I assume that it is doable, using the AKI for the paddles in Pong?
Again thanks  :)
Lilwolf
« Reply #4 on: February 21, 2005, 09:05:50 am »
btw, one problem I had..
98 requires you to have a button 1 to calibrate a joystick.  Hitting next doesn't register the difference.
It took me FOREVER to figure that out.  And only found out when I went to Daves site to send him the tech question when I read a warning on his site.
It worked GREAT on the beta chip set... But when I got the latest version (that seperated the joysticks into two) I had wired all my games to just buttons on joystick one.  And I didn't rewire.  So everything worked in mame (since it didn't care) but I never tried to recalibrate my T2 control panel.... And since I didn't have a button 1 on joystick 2... it wasn't happening...
But now with a quick rewire of buttons 1 & 2 on joystick 2... All is good
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
« Reply #5 on: February 21, 2005, 01:54:34 pm »
Sounds interesting, can you post some pics?
