Author Topic: Seperate folders for the roms?  (Read 1292 times)
redsquirrel2005
  • Last login:February 08, 2005, 04:40:40 pm
« on: January 30, 2005, 03:04:00 pm »
Hi,
Have not been here for about 9 months and forgot my login details  ::)
Anyway just decided to sort my mame cab out today and was wondering if there is any way to store roms in seperate folders than have them all in one (ie roms/). The problem is it is slowing my PC down to a halt because it has to list so many roms. I tried moving several over to a seperate folder inside roms/ but it could not load them. Mamewah only specifies one rom folder, so I am a little unsure what to do
any help will be much appreciated thanks
ryckster
  • Last login:February 05, 2005, 03:30:47 am
    • Dat Maker 2.0
Re: Seperate folders for the roms?
« Reply #1 on: January 30, 2005, 04:59:19 pm »
I think you can modify your mame.ini file and add as many directories as you need to the roms directory entry value on the file. I don't remember what is the name of the entry, maybe someone can answer that. You can sort your files to different directories manually or you can use an utility like Romcenter to do it for you.
