Author Topic: J-Pac / I-Pac  (Read 2102 times)
chris2922
  • Last login:March 26, 2023, 01:09:41 pm
  • Silverline Jamma Cab
J-Pac / I-Pac
« on: January 10, 2005, 01:42:37 pm »
Could someone please explain to me what the difference is between the J-Pac and the I-Pac.  I was going to buy a J-Pac and an ArcadeVGA to interface my JAMMA cab to a bare bones Pc.  Before I do though, id like to know what the difference is.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: J-Pac / I-Pac
« Reply #1 on: January 10, 2005, 02:11:50 pm »
They're both the same for inputs.  The J-PAC has the added functionality of being able to plug directly into a JAMMA harness.  It amplifies the video signal to a level the monitor can use.
krick
  • Gotta have blue hair.
Re: J-Pac / I-Pac
« Reply #2 on: January 10, 2005, 06:52:37 pm »
The J-PAC also has a video circuit that divides a 31KHz VGA signal so that it cannot damage your arcade monitor if you accidentally send it a VGA signal.
This is most useful for people running DOS cabs with AdvanceMAME and a "normal" (non ArcadeVGA) video card.
When booting with a normal video card, there is a brief period during the BIOS display where a 31KHz signal comes out of the card.  Then when AdvanceMAME loads, it reprograms the card to display a 15KHz signal.
Since my cabinet was already wired for JAMMA, I went with a J-PAC and an ArcadeVGA.  I also picked up an additional I-PAC2 so I could hook up the player 3 & 4 controls, and an Opti-PAC for the trackballs and spinners.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
chris2922
Re: J-Pac / I-Pac
« Reply #3 on: January 11, 2005, 07:55:20 am »
Great, sounds good.  I'll get on and order them then.  Thanks both.
paigeoliver
  • Awesome face!
Re: J-Pac / I-Pac
« Reply #4 on: January 11, 2005, 08:29:50 am »
Since I first used the Jpac I now reccomend them for everyone, not just people using arcade monitors. Wiring is simple and easy with a JAMMA harness. Not to mention a lot less fragile. Plus the J-Pac makes swappable panels a breeze.
If you have a J-Pac and a Bob Roberts JAMMA harness then you won't even have to THINK, as every wire will be labeled for you.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
Re: J-Pac / I-Pac
« Reply #5 on: January 11, 2005, 10:51:58 am »
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
Re: J-Pac / I-Pac
« Reply #6 on: January 11, 2005, 11:15:28 am »
I did not think you needed an arcade VGA if you got the jpac. I thought it handles the signal for the arcade monitor. Am I mistaken??
Thanks,
Patrick
the j-pac just makes sure the signal is at 31mhz. if your video card is not at 31mhz it just won't let a signal through. you can use lots of video cards if you are okay running advancemame in dos or there's powerstrip for windows that lets you run at a different frequency. check out this page for some various video card reviews for mame plus more info you'll prolly find helpful.
edit: thanks for the correction peale. i was on autopilot typing that up :)
« Last Edit: January 11, 2005, 08:36:38 pm by jened »
SirPeale
Re: J-Pac / I-Pac
« Reply #7 on: January 11, 2005, 11:20:42 am »
You got it backwards - it makes sure the signal is @ 15KHz, not 31.
krick
Re: J-Pac / I-Pac
« Reply #8 on: January 11, 2005, 11:54:56 am »
Thanks,
Patrick
Technically, you don't.  However, bear in mind that the J-PAC is not a video converter.  The signal divider feature is just a safety device to protect your arcade monitor.  You still need a video card capable of being reprogrammed to output a 15KHz signal.
Check out the "Hardware" link on EasyMameCab for more information...
http://easymamecab.mameworld.net/
Hantarex Polo 15KHz
danny_galaga
  • Last login:Today at 02:45:34 am
    • dans cocktail lounge
Re: J-Pac / I-Pac
« Reply #9 on: January 12, 2005, 03:14:10 am »
yes, yes! i like not thinking! that's completely gelled my plan for my upright then...
