Author Topic: Front end help  (Read 2772 times)
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
  • I want to Build My Own Arcade Controls!!
Front end help
« on: October 10, 2002, 10:32:17 pm »
Ok where to start. What I am looking to do, is have a front end that will totally hide. I know there are some things like this around but I want one that is extremly customizable (backgrounds, skins, add/remove emulators, etc...).
I thought I would ask here before I spend hours looking. The other thing I was thinking of is making my own in flash/vb. Why vb? because its what I know.
Flash on the other hand I dont. But I really like the way you can do things and not have it look windows-like. The idea I have is kind of hard to explain.
Sort of a 3d menu. It would be sort of a ring with pictures of all the systems and it would spin when the user presses left/right. it would be like a "O" but sort of laying flat down so you only see the few in the front. i know this probably doesnt make sense. but i doubt i could make it anyway.
ok kind of off track there because if i can find something that is customizable enough i wont need to do all that. any suggestions?
WHELP! As if you knew what an eternity was. Grovel before your true master!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Front end help
« Reply #1 on: October 10, 2002, 11:04:37 pm »
I bet when lazarus 4 comes out with 3Darcade's 3D models you could make a skin that does that.  not sure, will have to talk to HC on that one, this post belongs in the software forum.
  • Last login:Yesterday at 07:36:46 pm
Re:Front end help
« Reply #2 on: October 10, 2002, 11:57:11 pm »
Almost didn't see this one.  As sirp said... wrong forum. :)
Yes laz 4.0 will have various flash effects associated with the plugin.  And it is as customizable and un-windoze like as it gets as far as front-ends go right now.
But what you described is >p<'s front end in cyclarcade mode...  Just replace the default cabinet model with some kind of floating monitor/marquee model and your all set.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:Front end help
« Reply #3 on: October 11, 2002, 03:48:44 am »
yeah what you describe is 100% my fe in cylarcade mode and my favorite mode in my fe...to see it properly when you boot it up the first time...hit 5 and select arcade to go to the full mame set...then hit 7 to change form the fps arcade to cylarcade...see cfg\fe.cfg for all the keys you can use to find games faster then by rotating one by one ;-)
Peter
SirPoonga
  • Puck'em Up
Re:Front end help
« Reply #4 on: October 11, 2002, 05:08:04 am »
Peter
i didn;t know you had this mode:)  I have to redownload now!
darkmanx
Re:Front end help
« Reply #5 on: October 11, 2002, 07:08:56 pm »
sorry about posting in the wrong area. been a long week. I am downloading >p<'s right now and it looks interesting. i would like to see laz when it comes out also. anyone know if its on its way soon and where i would get it?
thanks for all the help
Re:Front end help
« Reply #6 on: October 11, 2002, 07:58:19 pm »
lazarus has been out for months man but only the upcoming version will support anything 3d...
www.oscarcontrols.com/lazarus/
