Author Topic: ePSXe and Dragon King  (Read 2098 times)
rod
  • Last login:February 12, 2005, 10:07:28 pm
« on: January 01, 2005, 07:32:47 pm »
Does anyone knows how to configure ePSXe to run on DK?
I get the emulator to launch but not the game,i'm trying to use the keypress wrappers.I tried everything but i'm no expert.
  • Last login:February 01, 2026, 01:32:52 pm
Re: ePSXe and Dragon King
« Reply #1 on: January 01, 2005, 10:19:47 pm »
I would like to give you an answer, but I really can't.  The truth is the keypress wrapper is ancient at this point and I haven't seriously used espsxe for quite some time.  Something different is in the works, stay tuned.
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
« Reply #2 on: January 02, 2005, 11:03:44 am »
i got it working on my cab ... not at home though so i cant get the files right now , i'll look at it when i get home tonight.
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #3 on: January 02, 2005, 04:38:50 pm »
This is how I've got it working, firstly my DK cfg for PSX games
[Config]
extension=.bin
path=d:\EMU\PSX\epsxe160\
exe=ePSXe.cmd
send rom path=1
send exit keys=0
command line options=
Then in my epsxe directory I've created the following cmd which is called from the above.
epsxe.exe -nogui -loadbin "%1 %2 %3 %4 %5 %6 %7 %8 %9"
Hope this helps
GSXR.
lucindrea
« Reply #4 on: January 02, 2005, 05:29:29 pm »
did mine a little differnt ..
[Config]
extension=.bin
path=e:\epsxe160full\
exe=e:\epsxe160full\psx.bat
send rom path=1
send exit keys=1
the bat file is
ePSXe.exe -nogui -loadiso %1
so basicly the same as above
rod
« Reply #5 on: January 07, 2005, 06:34:17 am »
Thanks a lot guys!I did what you said and it worked.I'm very happy and so is my kids.
  i don't want to be a pain in a butt but i have other questions about Z26 and pcsx2.
is it the same pattern that you guys wrote?
Anyway thanks so much
rod
lucindrea
« Reply #6 on: January 07, 2005, 08:13:58 am »
dont use either one myself , but basicly as long as it has a command line , it should be no problem ..
making and fooling with the lists and dats is the real adventure  ;)
start by working out what you would need to type in a dos window to get the emulator to launch AND launch a game ( any game ) .. then just feed that into the config but replace the game name with %1
edit:
did a quick google and found the command for the z26 . .it's
z26 filename
so a config should look somthing like ( rom path not needed i would guess as it will append the bin at the end if you dont give it to the program ) ... enuf work for me , do your own search on the other
[Config]
extension=.bin
path=e:\z26\
exe=e:\z26\z26.exe
send rom path=0
send exit keys=1
command line options= -vN
Command Line Switch Summary
      -)CC -- select controller on left port
              CC = JS -- joystick
              CC = PC -- paddle controller
              CC = KP -- keypad
              CC = DC -- driving controller
              CC = LG -- lightgun
              CC = CM -- CompuMate keyboard
              CC = KV -- Kid Vid tape player
              CC = ML -- Mindlink controller
              CC = ST -- ST mouse / CX-80 Trak-Ball
              CC = TB -- CX-22 Trak-Ball
              CC = AM -- Amiga mouse
              CC = NC -- no controller connnected
      -(CC -- select controller on right port (CC: see above)
        -! -- run interlaced games
        -0 -- start with player 0 hard
        -1 -- start with player 1 hard
        -4 -- allow all 4 directions on the joystick to be pressed
              simultaneously
        -b -- start in black and white
        -B -- enable screen captures to .bmp files.  Works with
              phosphorescent games.
       -cN -- color palette (N=0 -- NTSC  N=1 -- PAL  N=2 -- SECAM)
       -dN -- DSP processing level (N=1 -- low  N=2 -- high)
       -eN -- enable narrow video modes (N=1 or N=2)
       -fN -- enable phosphorescent effect (N=0 through N=100,
              77=default) The parameter is the frame mixing
              coefficient (0 through 100) which specifies how much
              the bright pixel is favored over the dim pixel when
              mixing the value of two frames. The default is 77. If
              you specify a value greater than 100 or less than zero,
              the effect is disabled for games that are automatically
              recognized as needing this effect, like Yars Revenge.
              If N<0 or N>100 the effect is disabled for games that
              are automatically recognized as needing this effect like
              Yars Revenge.
       -gN -- override game type
              N=1  -- Commavid extra RAM
              N=2  -- 8K Superchip
              N=3  -- 8K Parker Brothers
              N=4  -- 8K Tigervision
              N=5  -- 8K Decathlon & Robot Tank
              N=6  -- 16K Superchip
              N=7  -- 16K M-Network
              N=8  -- 32K Superchip
              N=9  -- 8K Atari -- banks swapped
              N=10 -- Spectravideo Compumate
              N=11 -- 32K - 512K Extended Tigervision
              N=12 -- 8K UA Ltd.
              N=13 -- 64K Homestar Runner / Paul Slocum
       -hN -- set the maximum number of scanlines to render (height)
       -iC -- [changed] inactivate PC-controller
              (C = K -- keyboard, M -- mouse, J -- joystick,
               S -- Stelladaptor)
       -jN -- [removed]
       -kN -- [removed]
       -pN -- paddle sensitivity (N=1 to 15 -- keyboard only)
       -PN -- enable lower sesitivity for PC joysticks / Stelladaptor
              in paddle emulation, and delay the paddle read-bit
              flipping by N scanlines
       -mN -- paddle to emulate with mouse (N=0 to 3)
     -m1XY -- emulate two paddles with mouse (X and Y = 0 to 3)
       -MN -- enable mouse capture in a window -- allows mouse full
              control of games in windowed video modes just like full
              screen modes  (N=0 -- off, N=1 -- on)  default = on
        -G -- Grab all mouse and keyboard events. Use this if your window
              manager's hotkeys conflict with z26 hotkeys. This option
              is primarily intended for Linux/UNIX systems, but may be
              useful on Windows as well.
       -lN -- [changed] adjust lightgun by N cycles
       -aN -- adjust lightgun emulation by N scanlines
        -n -- show scanline count and FPS on game display
        -o -- simulate PAL color loss
        -q -- quiet
       -sN -- specifies the size of the sound queue
             (default = 4608   --   max = 65536)
        -r -- Windows: run at monitor speed
              Linux:   This option doesn't work, and is disabled.
       -rN -- run at N frames per second. Give a large number
              (e.g. -r10000) to run the emulator as fast as possible.
              This option does work on Linux.
        -R -- Windows: synchronize with sound instead of display
              Linux:   This option doesn't yet work correctly,
                       and is disabled.
        -t -- write code trace to z26.log. Warning: These log files
              get ENORMOUSLY large. Try not to run out of disk space.
        -tt -- Same as -t, but start emulator with tracing disabled.
               Press F11 to enable trace while emulator is running,
               or F12 to disable.
       -uN -- start scanning game at line N
       -vN -- start game in video mode N full screen
      -v1N -- start game in video mode N in a window
        -w -- [changed] swap Atari controller ports for all
              controller types
        -x -- print checksum of cartridge
       -yN -- [removed]
        -z -- disable the fast copy routines
« Last Edit: January 07, 2005, 08:16:28 am by lucindrea »
rod
« Reply #7 on: January 07, 2005, 10:22:48 am »
Thanks i will try it.Talk to you soon.
rod
rod
« Reply #8 on: January 07, 2005, 07:50:50 pm »
i've got the game to launch but not in full screen,olso can't configure controls.
I'm problebly ot using the command line switch the right way.so i need some help.
thanks a ot for your time.
rod
