Author Topic: Ultimarc Trackball......how do you mount it?  (Read 1252 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: December 27, 2004, 02:13:54 am »
I figured out how to mount joysticks and pushbuttons into a wood panel, but I cant figure out how to mount the ultimarc trackball, just seeing if anyone that has done it can help me out, thanks.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
crashwg
Re: Ultimarc Trackball......how do you mount it?
« Reply #1 on: December 27, 2004, 03:06:16 am »
buy the mounting plate on the same site.  all you'll have to do is cut a large hole (a tad bit bigger than the TB) and drill 4 holes.  you'll bolt the mounting plate to the control panel and the TB gets bolted to that.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #2 on: December 27, 2004, 09:58:27 am »
If you don't have room for the mounting plate (6x6") or you just don't like the look you can try my method.  My cocktail panels are only 4 3/4" wide so a mounting plate was out of the question.
1. Use a 2 1/2" hole saw to cut a hole where you want the tb.  You will also want to slant the sides of this hole slightly as the top half of the trackball assembly is slightly slanted. I used a 15
97.4 percent of all statistics are full of crap.
Quarters
« Reply #3 on: December 27, 2004, 10:06:15 am »
top and bottom views of completed tb
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
« Reply #4 on: December 27, 2004, 12:51:47 pm »
I bought the mounting plates just to make my life a little easier. But- By the time you mount the plate, add an overlay and plexi, the TB barely sticks out at all. So, I took off the top 1/2 of the TB casing, and mounted it without it. I routed out the bottom of the CP for the CP to fit in, then used a chamfer bit for the hole UNDERNEATH. This makes the ball sit VERY high out of the CP, and makes up for adding an overlay/plexi on top. Here's the key tho- I used washers as spacers when mounting the TB to the CP. The washers (I used 11 in total on each of the 4 mounting posts) work to space the TB down away from the bottom of the CP so that the wheels will spin freeley, as well as the TB not hit the CP itself. You can use the washers to adjust how high/low you want the TB to stick out of the CP. I also used nuts on the other end of the mounting screws to make up for the lost length in taking off the casing top. This works beautifully, and the TBs are AWESOME!!!  Let me know if you need anything else...
D
the3eyedblindman
« Reply #5 on: December 27, 2004, 08:14:43 pm »
Thanks for all the replies guys!
