Author Topic: Power supply - - - namco 5-in-1 hack  (Read 2066 times)
LordDamo
  • Last login:December 10, 2008, 04:26:05 am
  • Damn it Jim, im a doctor not a machine . . .
    • The Kinddom of Damo
« on: December 20, 2004, 11:47:39 pm »
Just a quick question, please correct me if im wrong.
With a normal ATX power supply, the floppy drive power cable is 6v? And it the two outside wires that I use (for + and -), right?
Red for + and yellow for -.
I have a spare PWR supply laying around, and I was wanting to use it for a bartop namco 5-in-1 hack, rather than buying a transformer.. Wiill the amps be to high?
Thanks in advance.
Religious war is like two kids fighting over who has the stronger imaginary friend . . .
gobuchul74
  • Last login:November 03, 2012, 02:34:06 am
  • I want you to build my arcade controls!
Re: Power supply - - - namco 5-in-1 hack
« Reply #1 on: December 21, 2004, 12:14:33 am »
If I remember correctly Red to Black is 5VDC and Yellow to Black is 12VDC.  Don't worry about the amps. Amps are not pushed, they are drawn.  I don't think that little 5-in-one would draw more amps than a computer power supply could handle.
"We're going to take things away from you on behalf of the common good." - Sen. Hillary Clinton
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #2 on: December 21, 2004, 12:18:29 am »
Um, no.
5V and it is the red and a black.  I think the red and yellow are both hot, and the blacks are ground.
The 5-in-1 will want 6V not 5.  You could step down the 12V with some resistors, but it'd be much easier to get a black wall wart 6V ac-dc transformer and wire it to the wires in the 5-in-1.
LordDamo
« Reply #3 on: December 21, 2004, 12:21:04 am »
thanks man, you saved me blowing stuff up! Will 5v be enough you reckon?
True, just wanting to make sure, it was hard for me to find this thing, dont want to kill it straight away.
LordDamo
« Reply #4 on: December 21, 2004, 12:23:32 am »
Um, no.
cool - thanks, was just trying to use stuff i already had rather than spend another $20 on a transformer. There on special at Dick Smiths, I'll get one tomorrow.
gobuchul74
« Reply #5 on: December 21, 2004, 12:26:26 am »
It could probably run fine off 5VDC instead of 6VDC.  Sort of like running it with batteries that are slightly run down.  It would probably work, but who knows.....
LordDamo
« Reply #6 on: December 21, 2004, 12:30:25 am »
True, too true - didnt think of it like that. I'll give it a go. If it works, i'll let you know, so if others want to do the same thing they will know weather it works or not.
Thanks to everyone for your replys.
paigeoliver
  • Awesome face!
« Reply #7 on: December 21, 2004, 01:50:57 am »
DON"T DO IT.  :police: :police: :police: :police: :police: :police: :police: :police: :police: :police: :police:
A 5 in one game doesn't draw nearly enough current to use an ATX power supply. You will just burn up the power supply. Egads, just get a freaking plug in for it, they make them you know.
 :police: :police: :police: :police: :police: :police: :police: :police: :police: :police: :police: :police: :police:
gobuchul74
« Reply #8 on: December 21, 2004, 02:10:44 am »
I could be wrong, but honestly I've worked in electronics all my life and I've never seen a power supply circuit that failed because it had to little current drawn from it.
I'm probably just splitting hairs.
I do agree with getting a plug in transformer though.  I just picked up a couple 5-in-1's myself and plan on using a transformer myself.
paigeoliver
  • Awesome face!
« Reply #9 on: December 21, 2004, 02:27:58 am »
Switching power supplies need a load on them. I am not an electronics expert, so I can't explain WHY they need a load, but I know they do need a load. And 2 tiny chips (all that is on one of them things) is not a load.
LordDamo
« Reply #10 on: December 21, 2004, 06:29:33 am »
Thanks for your concern Paige, Im not going to do this - i'll just get a transformer from Dick Smith Electronics tomorrow - there on special :-)
