Author Topic: seen it before... xp on yer cab  (Read 3056 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: December 12, 2004, 12:45:49 am »
I saw it in another area... Had to get it straight. xp's min is like 128 mb on a 233 mhz proc'
well I setup mamewah on a 266mhz pIi with 267mbram? ish and after turning off the unused servces and themes, xp rox still. not I have doen the win2k bit as well but 98 is over.. so  so  so  so  over with... nuff said.mamewah + xp = the shizzat!!!
Minwah
    • MAMEWAH
Re: seen it before... xp on yer cab
« Reply #1 on: December 12, 2004, 10:36:54 am »
Cool, I've never seen XP on such an old PC...I've got an old 333 kicking around - might try it on there one day for a laugh :)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: December 12, 2004, 10:41:36 am »
While hard to read, your post seems to be informative  :-\
You installed from CD and proceeded to turn off everything, if I understood the chicken scratch.  What exactly did you leave ON there, what other information can you give us about your setup?  Are you using it in a cab or using the keyboard for controls for now?
« Last Edit: December 12, 2004, 10:44:13 am by DrewKaree »
mnm1200
  • Last login:March 10, 2006, 05:55:34 pm
  • IANAL: I am not a llama!
« Reply #3 on: December 12, 2004, 04:04:26 pm »
You could try something like XPLite.
You just have to disable the services you don't need (networking, etc.) otherwise via Administrative tools and also turn off all the visual options.
Windows may not look as nice but you do get a good boost in speed in my experience
Demon Dog? Urusai! ...Baka
  • Last login:Today at 01:15:50 pm
« Reply #4 on: December 14, 2004, 09:53:45 am »
Xp lite is crap, user beware!
Doing it manually via blackviper's tutorials should be ok though.
Yeah xp will run on any x86 computer, assuming you bypass the checks it uses to see if the pc is beefy enough.  You'd be suprised how well it runs on lesser systems too, it's just the bootup that seems to take forever.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #5 on: December 14, 2004, 10:24:11 am »
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #6 on: December 14, 2004, 12:35:50 pm »
Maybe he was cursing a lot and the autocensor is to blame for the unintelligible post.  Damn autosensor :)
Best Kid iPad Apps
Lilwolf
« Reply #7 on: December 14, 2004, 01:16:14 pm »
Hes from Michigan... It might be the water  ;D
Howard, have you used XPLite?  I heard it was pretty good, but it removed directX by default (or a setting).  Is that the only problem?
I would LOVE to see someone with a cab friendly XP settings...
Assuming mame, a few frontends out there... and a network connection only.
last time I tried to super/optimize XP it didn't boot... and I had to start over... sigh :-[
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #8 on: December 14, 2004, 03:32:19 pm »
Don't dis our water, Lilwolf from Ohio. >:(
Atleast our rivers don't catch on fire. :P
Lilwolf
« Reply #9 on: December 15, 2004, 10:52:33 am »
btw, grew up in Ann Arbor...
and I have not claimed Ohio as my state yet...
I openly wish I could afford to move back to Michigan... sigh...
DrewKaree
  • HAH! Nice one!
« Reply #10 on: December 15, 2004, 02:21:11 pm »
Hey lilwolf, I'm bettin' Ohio is wishing the same thing  ;)
Anyone ever try this for their cab, or has Howard scared you all from trying it and I'll have to be your eventual guinea pig?
Either someone's tried it and it sucked so bad they're embarrassed to post here and have Howard tell them he was right (and finally end these "Lite" discussions once and for all) or they're askeered to give it a go due to the boogeymen getting ready to infest their computer with random problems.
Either way, post 'em if ya got 'em....or something
mnm1200
« Reply #11 on: December 15, 2004, 04:56:45 pm »
UPDATE: Just tried XP lite on my MAME box
I have 64 of 149 components installed.
Windows starts in exactly 17 seconds and I'm seing quite a significant boost in overall speed.
« Last Edit: December 16, 2004, 05:31:52 pm by mnm1200 »
mnm1200
« Reply #12 on: December 16, 2004, 05:29:43 pm »
yepyep.
Now all that's left is finishing disabling services and turning the display settings down and Windows will be really flying! =D
« Reply #13 on: December 17, 2004, 11:36:57 pm »
« Last Edit: December 17, 2004, 11:42:15 pm by Howard_Casto »
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: December 18, 2004, 08:46:56 am »
it's impractical due to what it removes that you'll probably want to reinstall and and a lack of what it does for you.
Further details are available if you really really want them.
I used to use 98Lite and agree with the above comments.
It took a lot out, but then a lot of that had to be put back in, so what was the point.  It helped a little, and when I was using a Pentium 200 MMX, a little help went a long way, but on modern hardware (read a Duron 650 or better) I wouldn't bother.
OTOH, I didn't see the massive problems with it that HC tends to accuse it off.
Also, be a little careful with BlackVipers stuff too.  I ran that and then tried to install a Canon printer.  Was on the phone with Canon's Tech support when I realize one of the Services that I disabled on BV's recommendation was why the printer wouldn't install.
mnm1200
« Reply #15 on: December 18, 2004, 11:19:14 am »
*edit*
crap...  the forum ate my post
lilwolf, long story short, i have and while it's not as "dangerous" as the other lite programs, it's impractical due to what it removes that you'll probably want to reinstall and and a lack of what it does for you.  Turning off services is basically the extent of what it does to speed up xp and it does a strangely conservative job of it at that.  Black viper's tweaks will give you a better result, quicker, and for free no less.
I had already disabled most of the services on the machine im using for my cab but I already had XP Lite so I tried it on this one and it does help
