Author Topic: Enlarging mounting holes on the I-PAC board  (Read 1287 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« on: December 05, 2004, 02:18:12 pm »
I am going to mount an I-PAC without the mouting feet. I think I will use Peale's suggestion by using the bick pen method (cut into 5/8" pieces). I need to enlarge the mounting holes on the I-PAC board to accomodate a wood screw. Am I safe doing this or will I fry the board. Not sure if I will kill any *potential* circuits.
Thanks for the advice...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
mahuti
Re: Enlarging mounting holes on the I-PAC board
« Reply #1 on: December 05, 2004, 02:34:30 pm »
I used a drill to make the holes larger. No problem.
Jabba
  • D-Hutt
« Reply #2 on: December 05, 2004, 02:56:49 pm »
Thanks for the quick reply mahuti. Great, now I'm off to the workshop... :D
crashwg
« Reply #3 on: December 05, 2004, 06:37:00 pm »
Be carefull, you may just snap the hole larger and then it won't be a hole anymore.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #4 on: December 05, 2004, 07:41:36 pm »
As long as you dont break any leads your all good..
one note of caution..
the G5 resin material that the board is made of is a carcinogen and acts like silica or glass in the lungs..This stuff embeds itself in there and never comes out  :o ..this leads to the same types of problems that asbestos is associated with..nothing like dying from drowning in your own fluids!
in its solid state it is intert and safe to handle or put in your mouth if you so wished..
but the dust created by drilling milling or whatever is quite harmfull.
i recomend wet drilling .
« Last Edit: December 05, 2004, 07:55:26 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
paigeoliver
  • Awesome face!
« Reply #5 on: December 05, 2004, 08:45:34 pm »
I used a drill bit and spun it with my fingers, it didn't take long and then there was no chance of a slip up.
NoOne=NBA=
« Reply #6 on: December 05, 2004, 08:48:11 pm »
Foam sticky tape works really well for most applications, as well.
Lilwolf
« Reply #7 on: December 06, 2004, 02:51:32 pm »
buy..
smaller..
screws..
or use nails.. or use tape... or use mirror clamps..
but why drill on a $50+ item just to save a 10c screw?  Just too much of a chance to really really get pissed at yourself.
btw, I like the idea of mounting them in an old vhs plasic box... and screw that into the cabinet.  help protect them.
DYNAGOD
« Reply #8 on: December 06, 2004, 02:57:52 pm »
buy..
smaller..
screws..
great idea!!
ive had a mounting problem with my J-pac.
the egret cabinet is all sheetmetal so theres no where to screw it into and to add insult to injury, resting it on the metal could cause a short.
ill give that shot tonite!
