Author Topic: Act Labs GS issue  (Read 1505 times)
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Act Labs GS issue
« on: November 05, 2004, 12:42:22 am »
Although the Act-Labs GS is an older gun system, I managed to get ahold of one since USB versions are nonexistent or cost about $100 on eBay...after a little bit of coaxing I set up a computer with MAME32+ and got the first light gun working...however, i cant get the second player to pick up the second gun's input...is there any way to differentiate between the two? ???
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
Re:Act Labs GS issue
« Reply #1 on: November 05, 2004, 06:47:17 am »
Try using the Mame Anolog+ build of mame.
http://www.urebelscum.speedhost.com/
Has built in dual mouse support.
-FTen
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #2 on: November 05, 2004, 07:59:44 am »
For Mame Analog+ to work with multiple light guns, there are a couple of requirements:
If you're using Windows XP, and the the device behaves like a mouse (aka you can shoot the desktop and your mouse cursor reacts), then you should be able to use several of the lightguns with Mame Analog+.  USB, Serial, and PS/2 devices should definetly work, and anything else (gameport?) may be less likely to work.
If you're using Windows 9x, and the device behaves like a mouse, AND the device is USB, then multiple lightguns should work with Mame Analog+.
If you're using Windows 2000 then you are out of luck.  Only the newest guns (the tv light guns) would work.
Disclaimer:  I've never seen or tried the Act-Labs GS, so I can't promise that they'll work even if they meet the above requirements.
OMG!  I just looked, and you're right!  The USB light guns are going for mad money ($120?!?!?):
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=74943&item=5134482483&rd=1&ssPageName=WDVW
sc1103
« Reply #3 on: November 05, 2004, 09:06:10 am »
Thanks for the help, but the GS uses the joystick port, so in order to use it, I enable the analog joystick settings (plus the mouse settings just in case  :)) Unless Analog+ allows u to use th esame joystick i don't know if thatll work...
deoblo85
  • Last login:April 01, 2025, 01:22:30 pm
  • GAME or DIE
« Reply #4 on: November 05, 2004, 09:18:38 am »
I have 2 light guns but i cant get the first player working can you help i need settings for the game as far as lightgun axis y and axis x what do i do or press to enable them right because
thiers axis right ,left,axis this and that!!!!!!!!!!!!!! please help
terryd
  • Last login:October 27, 2005, 03:14:58 pm
  • To each his own... Unless I want it first!
« Reply #5 on: November 05, 2004, 09:19:49 am »
Hopefully Actlabs will see this and realize that there is a demand for PC light guns.  Hopefully the other posts are correct in that Actlabs will release a new version of the PC gun soon and put an end to the high prices!!!!!
deoblo85
  • GAME or DIE
« Reply #6 on: November 05, 2004, 11:04:21 am »
My lights guns are for tv only the price was'nt that bad -about $39 apiece.I don't know what guns are going for i just bought these because everyone i talked to said act-lab guns are the best.I have my hole machine done and running great i just need to map my guns to the controller can anyone help for instance lightgun axis right,lightgun axis left,lightgun analogX,lightgun analog Y.Can anyone help!!!!!!!!
