December 02, 2025, 08:03:29 am
I'm planning on using a couple of 12v car dashboard lights as my coin door lights.Is it perfectly safe to hook these up to the 12v power coming out of my computer? Don't want to fry the power supply or anything like that, so wanted to get some input from you cats on this.(I am planning on using the wires that would normally be used for an extra harddrive.)Mike
An alternative recommendation that I got from this board is to use Lazer LEDs. They were cheap, don't use alot of power and last a long time. I used a blue one to light up a trackball and a red one for the coin door.
Yes, it was simple because the LED came with a Molex connector. I did have to splice in a couple feet of extra wire to reach the coin door.
My coin door only has one light. I bought the single LEDs for $1.79 and it was enough light.
No, you'll probably have to buy two separate LEDs to light up 2 rejects.
Quote from: quarterstringer on October 19, 2004, 09:39:43 pmNo, you'll probably have to buy two separate LEDs to light up 2 rejects.So with two LEDs, can I hook them up in parallel to the computer power supply?
I'm interested in this too. I'm converting an existing Jamma cab and I've isolated the game board power supply. But it seems a shame to not utilise the light that's already in the loom for the coin door. I agree LEDs are better, but I may as well use what's already there.How would I wire this into the 12V supply for a second hard drive? Do I just splice the red and black wires from the block connector? As per original poster, I'm not too hot on computer electrics.
If I have blue coin slots, should I use the white or blue LEDs? And should I use 4 or 6 Led-heads?
