Author Topic: Where do i find super thin PLEXI GLASS ????  (Read 6119 times)
koolmoecraig
    • My Intervention
« on: September 22, 2004, 05:20:59 pm »
I need REALLY thin plexi glass to sandwich my marquee graphic. Anyone have an online source?
Thanks,
Craig
Jakobud
  • Last login:November 11, 2025, 01:07:55 am
Re:Where do i find super thin PLEXI GLASS ????
« Reply #1 on: September 22, 2004, 06:33:59 pm »
Do you have a Home Depot nearby?
Agent Davis
  • Last login:April 11, 2008, 04:14:41 pm
« Reply #2 on: September 22, 2004, 07:03:36 pm »
Hey man I found what you're looking for at home depot.  Can't recall what it's called but its flexible and real thin (not hard like plexi) and very easy to drill through without worrying about breakage.  1/16" or so.
koolmoecraig
    • My Intervention
« Reply #3 on: September 23, 2004, 01:59:10 am »
The problem is that this is for a Q*bert machine where the bottom of the marquee sits in a little groove and the top part if held back by a retainer bar. So it cannot be thicker than the groove. So I need REALLY thin stuff so the "sandwich" isnt too thick.
Home depot only had thicker stuff. Is there a name for the stuff that you got from them?
Thanks,
Craig
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #4 on: September 23, 2004, 04:40:01 am »
Polycarbonate is probably what he was using.  It's more flexible and easier to work with, but more prone to scratches than plexiglass.  The common brand name for it is Lexan.  Plexiglass is actually a brand name for acrylic.
A glass store will be able to order whatever you need, if they don't have it on hand.
Best Kid iPad Apps
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: September 23, 2004, 11:30:44 am »
You might also be fine with some clear but sturdy plastic sheets from an art store.
make your front layer the standard 1/8th" thick, and then your back layer can be the super thin sheets. Your retainer should hold it all up straight if it's tight enough.
NO MORE!!
Robopede
  • Last login:October 18, 2004, 11:24:52 pm
  • 80's rule!
« Reply #6 on: September 23, 2004, 10:39:19 pm »
Look inside and you will see
The dream is my reality
Rapid Axlr8ion
  • Last login:September 24, 2004, 02:09:55 am
  • When in doubt...Whip it out!!!
« Reply #7 on: September 24, 2004, 02:16:22 am »
If you want something really thin, try cellophane.  You can get a whole roll of it at a grocery store for under 3 dollars. ;D
Seriously though, I had the same problem.  Luckily there is a plastic company in my city called Lustercraft.  They can get any thickness from nothing to inches thick...  Good Luck
