Author Topic: connecting WG 9200 to jpac/arcadeVGA. VGA or wired to monitor board?  (Read 1502 times)
brandname
  • Last login:February 21, 2006, 03:38:36 pm
i decided to replace my blown 27" foreign monitor with the WG 9200.
the old monitor was connected with 5 wires (no VGA input) through a j-pac unit.
since the WG has a VGA input built-in, can i bypass the jpac and plug straight into the VGA output of my arcadeVGA card and still retain proper output of the entire range of arcade frequencies as i did before?  or is it a better idea to connect the arcadeVGA to the j-pac and rewire straight to the monitor board from the j-pac, and not use the WG vga inut?
thanks.
/patrick
whammoed
  • Last login:Yesterday at 09:56:11 am
  • Crack don't smoke itself
    • NiceMite
Re:connecting WG 9200 to jpac/arcadeVGA. VGA or wired to monitor board?
« Reply #1 on: September 14, 2004, 12:16:30 pm »
I believe it would be best to connect directly to avga card.  This way with the d9200 drivers, you can take advantage of the non-interlaced 640x480 that the d9200 is capable of.
brandname
« Reply #2 on: September 14, 2004, 12:20:30 pm »
thanks, i'm hoping you are correct.  i'd really like to NOT have to wire this in directly and risk blowing it up :)
can anybody with this setup confirm this is right?
« Last Edit: September 14, 2004, 12:23:19 pm by brandname »
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #3 on: September 14, 2004, 02:19:52 pm »
isnt the voltage output of the Arcade VGA too low to drive monitor.  thats what the Video amp is for in the JPAC isnt it? to bring a PC VGA voltage up to a level a monitor can work with.
id direct this question to ultimarc before you go doing anything..
and id like to know your results as i am going with a jpac and arc-vga myself.
« Last Edit: September 14, 2004, 02:21:07 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
whammoed
    • NiceMite
« Reply #4 on: September 14, 2004, 02:32:16 pm »
don't need a video amp for the d9200 (at least for the vga connector input...don't know about the other)  You can run the d9200 off any video card directly.
DYNAGOD
« Reply #5 on: September 14, 2004, 03:51:24 pm »
ah,
the D9200 specs 2.2 volts for the cga/ega connector..
the VG only required .7 volts
« Last Edit: September 14, 2004, 03:58:03 pm by DYNAGOD »
