Author Topic: T-Stick Long or Regular Shaft  (Read 905 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: September 04, 2004, 02:05:04 pm »
Hi guys,
I plan on buying a T-Stick Plus joystick for my arcade but I want the balltop for it so I will be purchasing that separately from www.ultimarc.com. I was wondering, if I'm following the Project Arcade book and my control panel will be 3/4" thick, should i purchase the Regular or the Long Balltop Shaft for it?
Thanks.
NoOne=NBA=
Re:T-Stick Long or Regular Shaft
« Reply #1 on: September 04, 2004, 03:17:46 pm »
Definitely the LONG ball-top.
The short ball-top will not fit the wood CP very well unless you top mount it.
As a side note to others here, the stock bat handle is about 1/2" taller than the long balltop (give or take), but the bottom of the grip part ends up about 1/4" lower than the bottom of the ball on the long balltop.
