Author Topic: Color Changing LEDS?  (Read 813 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: August 08, 2004, 12:10:22 am »
Does anyone know some other sources of color-shifting LEDS? I have purchased them from allelectronics.com before, and they are awesome...but the initial cycle shifts through all of the colors very quickly before slowing down.
I guess I'm just wondering if there are some other options for color shifting leds, because I can't seem to find any.
BTW, here is the link for the ones from allelectronics.com
http://www.allelectronics.com/cgi-bin/category.cgi?category=340200&item=LED-95&type=store
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Last Edit: August 08, 2004, 01:55:10 am by SpamMe »
rdagger
Re:Color Changing LEDS?
« Reply #2 on: August 08, 2004, 01:56:29 pm »
I bought some RGB LED's and then programmed an AVR to use PWM to cycle through the colors.  I was going to put the schematics and code online.  If you don't like AVR's, the same effect could be created using a 555, a counter and some transistors.  I know someone posted the schematics a while back.  Either way you can control the speed.
